11-30-2007, 03:11 PM
I have been collecting parts to do this swap, I had a Ranger with a 2.3 and it seemed to have more power than the 2.8 in my Bronco II and it got a lot better mileage.My Bronco II has the C-5 transmission, I found a 2.3 Ranger at the wreckers with a C-5 so I grabbed the bellhousing,blockplate,flexplate and torque converter.That should take care of mating the engine to the transmission.I am using a Duraspark distributor in my Bronco II with a GM HEI module so I will just use a 2.3 Duraspark in the beginning as I was thinking of starting out carbureted and then switching to fuel injection down the road.I am assuming 4 cyl Ranger mounts should work but I haven't checked it out.Radiator will probably be a 4 cyl Ranger one or the Bronco II one using the fox Mustang lower rad hose which connects on the drivers side and I will probably use an electric fan as well.
