OBDII Code P1409 - Ford Truck Enthusiasts Forums
OBDII Code P1409
Old 06-16-2001, 06:10 PM
theleetbeagle's Avatar
theleetbeagle theleetbeagle is offline
theleetbeagle is starting off with a positive reputation.
OBDII Code P1409
My scanner returns:
P1409 Electronic Vacuum Regulator (EVR) control circuit malfunction
Could some kind soul please elaborate on what the problem could be and how I can fix it? Where could I find the EVR on my '96 I6 F-150?
Thanks!
-Nick.
Old 06-19-2001, 02:43 AM
hood's Avatar
hood hood is offline
hood is starting off with a positive reputation.
OBDII Code P1409
theleetbeagle:
Try this website, its dedicated to OBDII. Hope you can find what you're looking for. Otherwise call your local Ford dealer and ask them to price one out for you.
http://www.obdii.com/obdii.html
1981 F-150 2WD STYLESIDE P/U
4.9L 1 BBL CARB
C6 AUTO
2.73:1 LIMITED SLIP REAR AXLE
STABILIZER BARS FRONT & REAR
6100 LB GVWR PACKAGE
ORIGINAL OWNER
198,400 PLUS MILES
100% STOCK & UNREBUILT
BUILT FORD TOUGH!!!
Old 06-22-2001, 02:49 AM
hood's Avatar
OBDII Code P1409
Ford/Lincoln/Mercury
code: P1409 (EGR Vacuum Regulator Solenoid Circuit)
Good luck...let me know what you find.
4.9L 1 BBL CARB
C6 AUTO
ORIGINAL OWNER
198,600 PLUS MILES
BUILT FORD TOUGH!!!
Old 11-26-2001, 02:35 PM
cotoole cotoole is offline
cotoole is starting off with a positive reputation.
OBDII Code P1409
Hello,
I just resolved a P1110 code (IAT Sensor.. Cost $21) and shortly after the replacement of the IAT sensor, I got the P1409 code. And this time the MIL comes and goes. First.. Where does the "EGR Vacuum Regulator Solenoid Circuit" reside?
and #2 has anyone else ever heard of this occuring?
I spoke with FORD parts and was informed it could be one or both of Vac Reg at $20.50 or the EGR Pres Valv at $73.93
I'm going to reseat the connectors on the two parts that ford suggested.. I hope this resolves the problems.
Regards, Chris
Old 11-27-2001, 01:23 AM
youngster youngster is offline
youngster is starting off with a positive reputation.
OBDII Code P1409
EGR Vacuum regulator should be on the driver side of the valve cover towards the back of the motor. There are three solenoids mounted on a bracket there. The black one with the round cap is the EGR VR. There is a filter located under the round cap that sometimes gets dirty and needs to be rinsed out in the kitchen sink. Just pop it off with your hand and you'll see what I mean. I clean mine every time I clean my air filter. You also might want to make sure the vacuum line isn't cracked. That will cause problems for this device, too.
The other two solenoids are the Thermactor Air Diverter and The Thermactor Air Bypass (TAD & TAB). Sometimes referred to as Air Management Solenoids 1&2.
Good luck
Old 11-27-2001, 01:52 AM
77fromheaven 77fromheaven is offline
77fromheaven is starting off with a positive reputation.
OBDII Code P1409
Old 03-01-2006, 08:14 PM
ted021 ted021 is offline
ted021 is starting off with a positive reputation.
P1409
My Ford Explorer 1997 Eddie b. V8 5.0..the check engine light was on..the mechenic checked it ..the code p1409 came on...the solinoid was 35.1 ohms..so the mechenic changed the EGR positioning sensor..but the light is still on..does anyone help whatelse need to be done?
Old 03-02-2006, 07:25 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome Ted021 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 08-17-2006, 08:43 PM
Hi FTE's,
I have not seen any responses to Ted's question.
I .. Once again.. have the P1409 error. I replaced the EGR solenoid and the MIL is still activated (despite reset). I checked the resistance of the old part and new part and both are close at around 35 ohms. Vacuum line looks ok. Is there any way to test the EGR Pres Valve? Any and all suggestions greatly appreciated!
-Chris
Old 08-17-2006, 09:38 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
If the solenoid has the correct resistance, you either have a wiring harness or PCM fault.
Steve
Old 08-17-2006, 10:35 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
What projectSHO89 said. OBD2 is smart enough to know the difference between a mechanical fault and an electrical fault. If you have a circuit code for the EVR solenoid there are only 4 possible causes: a bad EVR solenoid, a bad computer, open or short in the EVR power wire, open or short in the EVR ground wire.
Old 08-18-2006, 10:07 AM
This is great information. Thanks for the replies. Pardon my ignorance. Is there a good reference out there that can show where the ground, PCM and other connectors are located? -Chris
Old 08-18-2006, 11:30 AM
The PCM is in the driver's kick panel. It sends both power and ground to the EVR. I would just check both terminals of the connector with a test light and make sure both are doing what they should be.
Old 10-24-2007, 10:46 PM
EGR acting like a Prostrate
I have had this "recurring" problem with a P1409 code:
EGR Vacuum Regulator circuit malfunction
Electronic Vacuum Regulator Control circuit fault
I get this intermittent in the summer and it usually goes away after the temperature drops.
We are having out of season temperatures in NC these days, I am now allowing my daughter to drive
the vehicle.. And I'm NOW thinking it is time to dig further in how to resolve this.
Can someone out there tell me what the expected voltage is when the EGR solenoid gets activated?
Are one of the two contacts suppose to go to ground (I suspect so..)
Which wiring block to start looking at?
Any clues/direction would be greatly appreciated!
-Chris
Old 03-13-2008, 12:04 AM
bjcman bjcman is offline
bjcman is starting off with a positive reputation.
Smile P1409 quick check
I am new to this forum but you will alway have 12 volts on the solenoid terrminals when mesured using chassis ground at idle. That is because the computer has not yet "pulsed" the solenoid to ground..
Crank the engine and manually ground the terminal to the chassis that is opposite the termainl that has 12 volts on it when the connector is disconected.
The engine should idle rough or stall..indicating the solenoid and egr is working...
Quick check hur??
Bobby
EGR Vacuum Regulator (EVR) craigdallen 1987 - 1996 F150 & Larger F-Series Trucks 32 10-13-2014 06:28 PM
EVR problems again HELP!!! scrobbie 1987 - 1996 F150 & Larger F-Series Trucks 28 01-30-2014 09:52 PM
'99 Ford E150 Error P1409; engine randomly runs rough, stalls, low power. Pls Help. a_frenchswallow 1968-2013 Full Size Vans 6 10-29-2010 06:10 PM
P1409 code joycat1 Modular V8 (4.6L, 5.4L) 1 01-26-2004 01:02 AM
OBDII Code P1409 crazy_goodolboy 1987 - 1996 F150 & Larger F-Series Trucks 1 06-16-2001 06:11 PM
Tags
03, 1998, 42, 97, code, evr, explorer, f150, ford, lightning, locator, mercury, odb2, p1409, sable, solenoid, vac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
