You need the standard heat core. The high output is the same core that is used with A/C.
Hope this helps
__________________
1997 F250 XLT CC 4X4 4.10LS E4OD 240K(AB Cali Truck)
18K MOD
TYMAR
3'' DOWN PIPE
CAT DELETE
2" LEVELING
EGT,TRANS,BOOST,WATER,OIL,OIL TEMP,VOLTS
285/75/16 MASTERCRAFT COURSER CT'S
SONNAX VALVE and SPRINGS
30,000 lbs TRANS COOLER
