Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-29-2007, 12:03 AM
misnomer misnomer is offline
Garage is empty, add now
misnomer is starting off with a positive reputation.
hoses & seals ???
I hear various things about effects of WVO & Biodiesel on fuel lines. How significant are the effects? Is there a place where the varying effects are posted? Viton I hear is the material of choice.. but it is $13+/ft, and I don't think I can get it locally. Tygon (F4040A) is much cheaper $2-4/ft and lots of places carry it. But I have not seen a report about its use with Biofuel.
I have the rear tank out of my truck installed a HotFox, I was thinking of just using standard rubber fuel lines.. but started thinking about the hassel of having to replace the fuel line to the tank again.. I really dont want to be pulling that tank again if I can help it.
How about getting seals for the injection lines for older engines. If I buy a kit will it still be made with OE material?
  #2 (permalink)
Old 11-29-2007, 11:58 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If your truck was made after 1994 you probably already have vitron fuel lines.
If it is older than that you should get them.
While $13/ft is expensive remember it is a one time deal why take a chance on somthing that "MIGHT" work.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 11-29-2007, 03:31 PM
1984 6.9L F250, no vitron on her. The hard lines are stainless, then the last few feet to the tank are rubber. I just wish I knew a local supplier and didn't have to wait for a UPS shipment again.
The o-rings started leaking also, are all the kits now made with vitron o-rings? or are there some brands I should avoid?
  #4 (permalink)
Old 12-05-2007, 09:40 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Get some good heavy strong rubber lines, and they won't rot away anytime soon.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #5 (permalink)
Old 12-07-2007, 07:19 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.Fat Diesel has a great reputation on FTE.
Quote:
It took about a year for a pinhole leak to start in a nice heavy rubber 30R7 line of mine.
__________________
Andy
2012 Race Red Boss 302 "Commuter Car"
Early 99 F250 PSD 4x4 CC 6spd Common Mods 260,000+ Miles, Driven daily like a rented mule
1964 Falcon Convert 289 Toploader 9" 4 Wheel Disks
Nov '10 Recipient: "dedicated report-back tech thread poster" award!
  #6 (permalink)
Old 12-09-2007, 10:35 AM
DieselFuelOnly DieselFuelOnly is offline
DieselFuelOnly is starting off with a positive reputation.
I use AQP hose made by parker or aeroquip. We use it on ships and it handles everything from hydrualic oil, #2 diesel, JP-5, Lube oil, jacket water... you name it.
Good stuff and its not that terribly expensive.
__________________
Ryan Popiel
late '99 F-250 Ext Cab, 8ft Bed
7.3L Turbo Diesel / 6sp Manual
4" Turbo-back Magnaflow Exhaust, ATS Turbo Housing, Wastegate Mod, 6637 Filter, Superchips Micro-tuner
  #7 (permalink)
Old 12-14-2007, 06:28 PM
Thanks... it isn't too bad $3.50/ft.. but then I would need to buy fittings for it, corect? or are you able to just slide it on and use hose clamps? The fittings are $5-6 each which doesn't make it much of a cost savings... and I know Viton works.. I ordered enough Viton for the fuel lines from the tank... I might experiment with the return lines.. i can see the return lines having more trouble since they move hot fuel in them.
__________________
1989 F250 4X4 SuperCab 7.3L NA (for now) 5sp 4.10 LS
1984 F250 4X4 SuperCab 6.9L ATS 093 Turbo T19 3.54
1985 F350 Flatbed 6.9L NA T19 (down)
  #8 (permalink)
Old 12-27-2007, 02:26 PM
Fat Diesel's Avatar
Quote:
Had another pin hole leak yesterday. I really need to get the teflon hose installed...
__________________
Andy
Tags
f4040a, tygon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
