Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 02-05-2008, 11:15 PM
jottoh12 jottoh12 is offline
jottoh12 is starting off with a positive reputation.
Smile If I use the 4.0L and 4R55E...
Quote:
Originally Posted by 96_4wdr
the SHO 4 cyl is rare
best to go a 4L Aero V6 from later model w tranny. far more take off torque, easy on gas and cheap compared to the hi pro exotics. parts are easy to find and cheap also
If I go this route, Is it most likely a direct fit to an 89? I have found a donor AWD, a 94 I think. Can use some or all its parts or should I find a 2WD donor? Forgive all the questions but I have never seen (crawled under and through) anything but older aerostars and am unsure what frame/body changes have occured.Thanks in advance for your time.
  #32 (permalink)
Old 02-06-2008, 02:32 AM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is starting off with a positive reputation.
The later model SHO Taurus had a 3.2 or 3.4 liter v8. Now there's a compact v8, but again, the heads and intake would be too big to fit in the Aero's engine compartment.
  #33 (permalink)
Old 02-06-2008, 10:29 PM
93nighthawk's Avatar
93nighthawk 93nighthawk is offline
93nighthawk is starting off with a positive reputation.
Quote:
I would go with a clean 3.0L Aero. The 3.0/3.2L SHO block will bolt right up to the tranny and motor mounts without any modification (it's lower exterior is the same as the 3.0L in the Aero.) The only modification you would need to do is the wiring engine harness, and make room for the heads/intake.
The 3.4L is a whole nother beast. I personally would not touch a used one. To many of the used ones have bent valves and pistons. It is also based on the 2.5/3.0L Duratech engine found in the Taurus SLO's and Contours. You would be looking at more modifications to the tranny and motor mounts.
__________________
'97 Ford Aerostar AWD 4.0L v6 AT 84k mi
'07 Ford Taurus SE 3.0 Vulcan ATX 42k mi, Last of the original Tauri
My Car Domain
The Possum Aero-Van!
  #34 (permalink)
Old 02-07-2008, 10:10 PM
peganit2's Avatar
peganit2 peganit2 is offline
1977 Ford F-250
peganit2 is starting off with a positive reputation.
Noob here with an Aerostar.
I thought I'd never see an Aerostar forum but here it is! Cooool.
Unlike Aerostars
I love my Aerostar. Smooth, reliable, peppy enough and I think it's a good looking little vehicle. And it's WAAAAAAAAAAAAy better then my buddies AstroVan.
The only thing the Aerostar needs is a comeback. I'd get another one.
I saw an ebay ad once for an Aerostar with a 5.0L HO 5spd!
It took a lot of fab work but it was done nice. Wild. You could get away with murder in that thing.
I think there's more room in there than it looks like. A V6 SHO might fit without cutting it up.
I'm not touching mine. I like it just the way it is.
  #35 (permalink)
Old 07-03-2009, 05:52 AM
V8aerostar V8aerostar is offline
1991 Ford Aerostar
My Garage
V8aerostar is starting off with a positive reputation.
i love mine too. first car, BUT im currently putting a 302 in mine. with a holley 4bbl carb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
