How high can you go? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-30-2007, 02:06 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
I only have hydraulic blinker fluid. Will that work?
Old 11-30-2007, 02:16 PM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
Quote:
Winter or Summer Wt?
Bill
Old 11-30-2007, 02:48 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE.kawa has a good reputation on FTE.kawa has a good reputation on FTE.
I found the problem!!! Some dumb SOB (Don't ask me who I think it is) some how got the spring in the FPR cocked and it folded four (4) coils over and jambed the whole shabang up. (Did you know the pump was capable of 100+ Lbs?)
Now...having one hell of a time straightening the spring . No matter what I do it still is a little out of line. And to everyones amazment the "Stealership" don't have one but can order the valve "Kit" for $35.00.
But for now I need to get this beast on the road again so here is my question?
1) If I put the bent end of the spring in the valve the valve can't slide up the spring. (Not sure if it does that anyway) or, I put the straight end in first and hope that the little "Tit" on the cap will hold the spring in place.
Any suggestions from anyone (Bill?) are always welcome.
Rog
At least I know that it wasn't my Cadillac Battery Water. lol
Old 11-30-2007, 03:09 PM
kawa's Avatar
Rog
Ask me if I'm a happy camper???
I put the misalined end of the spring into the valve and put it all back together. Fired it up and I have 74 Pounds of fuel pressure at idle. It holds at 60# when I shut down.
Thanks for everyones help, This has to be the greatest forum around
Roger
Old 11-30-2007, 03:15 PM
MADVAN's Avatar
CooL!
Bill
Old 11-30-2007, 03:26 PM
plowhand's Avatar
plowhand plowhand is offline
Playing in the Dirt
plowhand has a good reputation on FTE.plowhand has a good reputation on FTE.
From post #11 [QUOTE=plowhand] The fuel then returns to the high side of the pump and is pumped out under high pressure (over 100 psi)[QUOTE]
Glad your back up and running!!!
Old 11-30-2007, 04:40 PM
250turbo 250turbo is offline
250turbo is starting off with a positive reputation.
great job !
Old 11-30-2007, 05:21 PM
kawa's Avatar
Thanks to all of you and a great BIG thanks for not asking who the:
DUMB SOB WAS!
Rog
Old 11-30-2007, 05:47 PM
plowhand's Avatar
Playing in the Dirt
DUMB SOB WAS!
Rog
O.K. since you asked ..............Who was the Dumb SOB?????????????
Just kidding, we've been there at one time or another.
Old 11-30-2007, 05:57 PM
MADVAN's Avatar
DUMB SOB WAS!
Rog
X2
LLIB
2001 Navigator 5.4l 32v intech V8 timing 01ArizonaGator Modular V8 (4.6L, 5.4L) 8 04-21-2013 01:26 AM
Ford V10 cam timing CR's Ford f250 SD 1999 to 2016 Super Duty 0 07-09-2011 03:43 PM
Isspro trans temp gauge acting up Franko72 1999 - 2003 7.3L Power Stroke Diesel 11 02-26-2010 02:36 AM
fuel injector pump help ASAP!!!!!!! Miterez Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-16-2005 10:08 PM
84 F-150 300 6 with timing problems gunpowder 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-28-2001 01:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
