2-speed rear axle - Ford Truck Enthusiasts Forums
2-speed rear axle
Old 11-28-2007, 12:25 PM
big_i80 big_i80 is offline
big_i80 is starting off with a positive reputation.
2-speed rear axle
I was wondering if there has ever been a 2 speed rear axle for ford trucks? I recall a friend saying his old power wagon had a 2 speed rear end. Does anybody know? Make model, experience?
Old 11-28-2007, 02:26 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
medium and large duty trucks, yes. pickups, no.
except for the model t.
the model t could be had with a 2 speed rear. if i remember correctly, it was called a ruxtle or ruxby rear.
Old 12-05-2007, 08:01 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
The smallest one was the EATON 1350
It was used in the F6/600 trucks from about 1947 - 1960. (1.5 TON )
They're pretty scarce nowadays. replaced by a larger axle for F-600's in th elate 50's.
It would be way too big for any pickup..... PLUS, the highest ratio ws 5.83:1 HIGH and 8.11:1 Low
cheers,
Rick
Old 12-07-2007, 08:08 AM
blue beast's Avatar
blue beast blue beast is offline
blue beast has a good reputation on FTE.blue beast has a good reputation on FTE.
Get a Klune under drive unit and split your gears.
Vehicle Speed Sensor and Rear ABS Sensor the same? 1995droptopz 1999 to 2016 Super Duty 2 07-15-2011 09:48 AM
69 F600 rear axle swap AHOLLEY19 1967 - 1972 F-100 & Larger F-Series Trucks 1 01-06-2011 07:59 PM
'56 F-660 rear axle compatibility barbsbuddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-26-2008 06:13 PM
Big Trucks, rear ends HT32BSX115 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 09-05-2005 01:09 PM
2-speed rear!! enduringexplorer 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-15-2002 11:54 AM
Tags
1955, axle, drive, eaton, end, f250, f600, ford, parts, ratios, rear, sd, speed, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
