89 f150 m52d 5 speed shifting problem
Since i bought my truck its had issues going into 3rd(a few years ago). I just thought it was syncros so i was waiting for the right time to pull it an rebuild. Im able to shift smoothly if i time it right and the truck doesnt get driven often so i just let it go. Last week i pulled the tranny and transfer case and cracked them both open to check everything out. Previous owner told me the truck had a new motor and trans with about 50k on them. Anyways this is what i found. ps, ive only put 15-20k on this truck in 3 years.
you can see the shift fork is machined down pretty far. Nothing else is worn which is odd. All the bearings are in good shape, none of the seals are leaking, none of the gears show any wear. Any ideas why this would happen??? Obviously im going to replace the shift fork but i want to make sure this doesnt happen again.
Is the end of the shifter arm supposed to have a plastic wear bushing on it? this one didnt. everything seems to slide okay, obviously there are detents. I guess id just like to get some insight.
Thanks ahead of time.
the slider was perfect. What i think happened was the previous owner told me the ford dealer put a new motor/trans in. i think they were rebuilt units and i think this shift forks was like that because there is no way from looking at the rest of the parts, this could have happened. I was thinking there should be some wear parts in there but i cant find any.
ps im not 100% on the terminology of these trannys as there seems to be alot of conflicting info out there. was the m50d used in explorers and rangers, then the m52d used in trucks. I have found info that points to both.
Would be interested in knowing how the tranny shifts into 3rd after you make the repair. I say that because I have an 03 with the 5 speed manual - 49k. Shifting into 3rd from the day the truck drove out of the dealership has always been iffy. Meaning that if one doesn't power shift and hesitates just a bit before shifting into 3rd, especially when downshifting with a lot of revs than all is fine. But if one tries to force the shift than nashing of teeth will be the result. Over the years and many readings on the site, most everyone with a M50D has the same story.
masseysbronco
03-01-2016 08:42 AM
FrozenOcean_xXx
03-11-2015 12:03 PM
TelefunkenU47
05-24-2011 10:28 AM
