B20 @ 32 degrees - Ford Truck Enthusiasts Forums
B20 @ 32 degrees
Old 11-28-2007, 12:29 PM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
B20 @ 32 degrees
So it was 28 degrees out this morning was really worried about gelling. There was no problem and the truck started and ran fine. I was wondering what would be considered too cold for B20? Also I have to splash mix B99 with #2 diesel. How well does it mix? What I do is fill up with #2 diesel then drive a few miles to the bio diesel station and fill up the rest of the tank with B99. This is only my second tank with bio so I am new to all of this.
Old 11-28-2007, 09:23 PM
diverseth's Avatar
diverseth diverseth is offline
diverseth is starting off with a positive reputation.
Last month i was in Asheville and it got down in the teens and my truck started up no problem just MUCH quieter. I was using B20 that I got from a Texaco station without any additive. It was my first time using BIO so I was a little nervous but my truck ran awsome in the BIO.
Old 11-28-2007, 11:23 PM
MikeSDK's Avatar
MikeSDK MikeSDK is offline
MikeSDK is starting off with a positive reputation.
Go to biodiesel.org and look for articles on cold weather performance. I am also running B20 exclusively, here in Nashville. It has gotten down to the high 20's, and I've had no issues..
If I remember correctly, I think I saw where B20 should be good to around 5* to 10* (may have read the graph wrong) without additive like Diesel Kleen.
Old 11-29-2007, 10:28 AM
tndiesel tndiesel is offline
tndiesel is starting off with a positive reputation.
I also live in Nashville, where do you get it in Nashville? I want to try some bio in my 7.3.
Old 11-29-2007, 10:41 AM
MikeSDK's Avatar
Here is a link showing sites of filling stations in TN that carry bio:
http://www.biodiesel.org/buyingbiodi...tate.asp?st=TN
I generally get mine at the Shell station at the Long Hollow Pike exit (Hendersonville) on I-65 N....or, if I am near Brentwood / Franklin, the
Shell station at the Moore's Ln / Mallory Lane intersection also carries B20.
There are several other stations locally that carry it, but those are generally the ones that I am near most often.
Runs great!
Old 11-29-2007, 11:30 AM
tazo's Avatar
Thanks for the info guys. I get a bit nervous with this truck. It seems to be extremely sensitive to change. The check engine light went on this morning. I will have to get my code reader and see whats going on.
Old 11-29-2007, 11:51 AM
MikeSDK's Avatar
Guys, remember to be sensitive about changing your fuel filters frequently for a while after switching over to bio. It is a solvent, and will clean your fuel system of the crud #2 diesel leaves in there....and it ends up in the filter.
I changed mine at oil change intervals (@5000 miles) the first few times after I switched.
Old 12-04-2007, 03:46 PM
tazo's Avatar
http://nbb.grassroots.com/08Releases/cold/
Thought I would share this with everyone.
Old 12-05-2007, 10:06 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
I didn't notice anything unusual when I started using BIO, but my fuel system is really, really clean as evidenced by NOTHING being in the tank after 100k miles.
BUT- I do notice my filter on my Dahl 100 pre-pump filter clogs faster on B99 than on #2. Not sure why, since there is a big ol filter right on the pump as it comes out...
I use a combination of my fuel pressure gauge in the cab and a vacuum gauge mounted between the filter and the pump to monitor the status of the filter. Pressure drops down to, oh about ZERO psi at WOT if I let it go too long!
Bio Fuel ? HamRad 1999 - 2003 7.3L Power Stroke Diesel 4 05-23-2014 12:28 PM
SOME BIO DIESEL INFO StanleyZ 6.4L Power Stroke Diesel 0 08-16-2012 03:22 PM
Bio Diesel Concerns John with beastly 302 Bio-diesel, Propane & Alternative Diesel Engine Fuels 9 03-20-2008 07:02 PM
B20 WonderDonkey 1999 - 2003 7.3L Power Stroke Diesel 7 11-21-2007 09:26 PM
B99 ok to run? RedStroker6 Bio-diesel, Propane & Alternative Diesel Engine Fuels 13 05-08-2006 05:14 PM
Tags
32, 60, b20, cold, degree, ford, trucks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
