edge code popped up??
have a 04 stx 4x4 thought i would try out 4x4 before the snow comes well worked great but then edge reacted different, through a cod eof P1000, On board diagnostic systems, readiness test not complete, going in to 4x4 has this happened to anyone at all ? or shoudl i not worry, and htink it was a fluke? put truck back to 2 wheel drive, set edge back to stock program, waited few minutes went back to setting 2 cleared the code and it was fine, when it did happen truck went into lymp mode, where the little wrench light showed?? weird
I have a 2006 SCAB 4x4 with the edge. I was in mode 2 on the edge and went into 4x4 about 2 months ago and had the edge through out a code. What clued me in was the truck started running rough and would not accelerate. I was climbing a hil at the time and just got over the ridge with. I turned off the engine and rest the edge to stock mode and the truck ran great. The code was gone and I had no more troubles. I have not tried mode 2 in 4x4 since then. Hopefully it was a fluke.
So I responded to this several days ago stating that I have not had any problems after being in 4 wheel drive. I was in 4 wheel drive all day today. By the end of the day, I noticed the truck being a little sluggish. I also noticed a sulfer smell and then the check engine light came on. After being home for a couple hours, I went back out to the truck and I was going to check the code but there wasn't one. I thought I should put it back in stock. I drove it for a short while then I went back to 3. When I was in custom tunes it would not let me, It said something like vehicle does not support contact tech support. All I was trying to do was load previous setting. I will be calling support on this but I thought it was interesting after being in 4 wheel drive all day. Maybe connected or not?????
