Seatbelt waning siren
I am wandering if anyone knows how to stop the annoying seat belt chime that rings when you dont plug it in. Its in my company work truck, and I am always in and out of truck so the chime gets really annoying. Someone had mentioed a sequence that you can do by turning ignition on and off a certain amount of times. Has anyone heard of this???
Thanks, Shane
Thanks, Shane
LOL -yeah its rediculous isn't it... Its not bad to have an alarm its just too loud. Take some tape and cover the buzzer.
***** Do not do the following. If you get hurt because you didn't wear your seatbelt ITS YOUR OWN FAULT! Always wear your seatbelt!
The rediculous process is in the manual goes something like this for my truck
Set the parking brake
Turn the ignition OFF
Seatbelts unbuckled
1> turn the ignition on but do not start the engine
2> wait until the safety belt light turn off
3> within 50 seconds of step 2 buckle and unbuckle the seatbelt 9 times ending with the belt unbuckled
The restrain warning system light should show for 3 seconds
4> Within 10 seconds of the light turning on buckle and then unbuckle the safety belt
You must repeat this process for each seat!
Seatbelts unbuckled
www.fleet.ford.com you can find a manual too.
I havent done this but this is what I have seen posted before:
Permanent deactivation: There are 9 steps you need to follow to deactivate or activate your Belt Minder system. Before doing so, make sure that: The parking brake is set. The truck/car is in Park (automatic), Neutral (manual). The ignition is OFF. All doors are closed. The driver's safety belt is un-buckled. The parking and headlights are OFF. Then follow these 9 steps:
Turn the ignition switch to ON, but DO NOT START. Wait for the safety belt warning light to go OFF(1-2 minutes). Steps 3-5 MUST be completed within 60 seconds!
Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled. Turn on the headlights, turn off the headlights. Buckle, then un-buckle the driver's safety belt 3 times, ending with the belt un-buckled. After step 5, the Safety Belt Warning Light will be turned on for 3 seconds.
Within 7 seconds of the safety belt warning light turning OFF, buckle then un-buckle the safety belt. This will disable the Belt Minder if it is currently enabled, or enable the Belt Minder if it is currently disabled.
Confirmation of the disabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds. Confirmation of the enabling of the Belt Minder is provided by flashing the safety belt warning light 4 times per seconds for 3 seconds, followed by 3 seconds with the safety belt light off, then followed by flashing the safety belt light 4 times per second for 3 seconds again. After confirmation, the deactivation/activation of the Belt Minder procedure is complete.
Originally Posted by gpeade
yeah, it' really aggrivating when hopping in to drive through the woods hunting. Really don't see the need for the belt on a 5mph trip.
black04lariat, you mentioned the word permanent, is this correct? Is it not reversable once done?
Seatbelts unbuckled
Seatbelts unbuckled
