squeak in reverse - Ford Truck Enthusiasts Forums
squeak in reverse
Old 11-27-2007, 03:03 PM
fordtruck1775 fordtruck1775 is offline
fordtruck1775 is starting off with a positive reputation.
squeak in reverse
when i back up i hear a squeak, sounds like something plastic is rubbing, i have checked the parking brake shoes and the ring around the front axle shafts i cant tell if anything is bad or broken, it only does it in reverse.
Old 11-27-2007, 03:04 PM
sorry its a 1999 f150 4x4 ext cab, 5.4 130,000 miles
Old 11-27-2007, 03:21 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Its probably dry ujoints
Old 11-27-2007, 10:54 PM
02crew's Avatar
02crew 02crew is offline
02crew is starting off with a positive reputation.
i had the same problem beat mt head against the wall trying to figure it out. try spraying some pb blast or wd40 all over the ujoint. it keeps it quiet till you can fix it. fixing it is another story. good luck
Old 11-27-2007, 11:57 PM
thank i will try that in the morning
Old 11-28-2007, 09:47 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Had the same thing and it was a bad U joint.
01 Ford Ranger Reverse Squeak and engine noise. Nicholas.Quirk Ranger & B-Series 4 10-14-2013 09:21 PM
Front end squeak AkF250HD 1987 - 1996 F150 & Larger F-Series Trucks 2 08-07-2013 07:31 PM
Squeaks when in reverse... rbsample 1999 - 2003 7.3L Power Stroke Diesel 14 06-06-2011 11:21 PM
UPDATE ~post 9... Squeak from transmission in drive and reverse question expy37at 1997-2006 Expedition & Navigator 13 05-25-2011 04:58 PM
Squeak Squeak Squeak when turning left WickedSharp 1999 to 2016 Super Duty 11 01-13-2011 10:10 PM
Tags
03, 1997, 2001, 2007, brakes, escape, f150, f250, ford, reverse, sqeeks, squeak, squeaking, squeaks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
