Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-24-2007, 08:26 PM
Don/TX is starting off with a positive reputation.
Swap 3.0 for 3.8 Problems?
I recently bought a 35 Mercedes 540K Kit car. It was bought in 1988, and has never been unpacked. The original purchaser died a few months ago. He paid a lot of extra to have the frame and other parts set up to accept a "Ford V6", motor mounts and transmission mounts.
My problem is, I have not kept up with the Ford V6 over the years. I am assuming that it is set up for a 3.8 and automatic from what was around back then, but I really want to modernize as much as possible, am looking for a late model engine/transmission unit I can pull from a more modern rear wheel drive vehicle.
My question is, are the 3.0 mounts the same as a 3.8? Would a 3.0 drop right in on the mounts? What is a good late model V6 vehicle that would yield me a good engine/tranny unit for this application? Any guidance appreciated. I don't want to change all the mounts.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-26-2007, 10:28 PM
OK, I got a bit smarter today. The V6 this car was engineered for was a 2.8 V6, because they are a 60 degree V, I think the 3.8 is a 90 degree angle.
I then have a question, since the 2.8 grew many variations up to a 4.0, are all the 60 degree V6 Fords using the same motor mount system?
It seems Ranger pickups used the 60 degree engines with rear wheel drive automatics mostly.
  #3 (permalink)
Old 11-27-2007, 01:18 PM
Interchange between 60 degree V6 engines
I have found that in the 60 degree v6 Ford engines, they range from small to large, apparently the same block.
If one had a 2.8 engined vehicle, and wanted to modernize with another 60 degree engine, which ones would bold in as a direct replacement (disregard the fuel injection and other minor modifications, I am talking only motor mounts here)
  #4 (permalink)
Old 11-28-2007, 03:26 PM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
I know the 3.0 and 4.0 share the same block...
  #5 (permalink)
Old 11-28-2007, 08:26 PM
havi's Avatar
Starting over IS my style
havi is gaining momentum as a positive member of FTE.
I would look into the bronco II/Ranger swap forums, as these were all put into those trucks. I'm sure that a 2.8 is not a 2.9 (efi), not even close, and the 4.0 bolts into a bronco II where the 2.9 was. Now if the 2.8 shares the same motor mount location as a 2.3 I4, I'd be looking for a 2.3T from an 80's turbo-coupe. My 2 cents. Anyhow, I'd snoop around in those forums....they probably know more.
__________________
Foster Brookes was a comic le....leg..lege...genius!Game On!
The Good1948 F1: awaiting an S10 T5 tranny
The Bad1987 TC: awaiting funds for parts
And the Ugly1962 Fairlane: awaiting everything
  #6 (permalink)
Old 11-28-2007, 08:36 PM
Thanks guys, that is a help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
