Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-26-2007, 06:22 PM
carphead is starting off with a positive reputation.
97 F150 will not idle
Starts, will stay running as long as you're giving it gas. Dies when you let off. Runs fine in reverse/drive.
What progression of checks would you suggest.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-26-2007, 08:23 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
Welcome to the forum!
No idle is usually the IAC (Idle Air Control valve). It doesn't throw any codes and the trucks performance will vary. Some are able to clean it and others just replace it.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 11-26-2007, 08:34 PM
Gevans17 is gaining momentum as a positive member of FTE.
no idle without foot
ditto on the IACV
  #4 (permalink)
Old 11-26-2007, 09:56 PM
MaLLoF150's Avatar
MaLLoF150 is starting off with a positive reputation.
i drive a 1999 ford f 150 4X4 with 79,000 miles on it and this is the first major problem with my truck..i had the same problem today and for awhile now..but i would like to know how much this idle valve cost? also where is this located? i also noticed it does it when its cool outside..my truck just have it's day now i guess lol
  #5 (permalink)
Old 11-26-2007, 10:09 PM
I just checked $48.99 at Autozone. I believe it's mounted to the throttle body.Driver's side? Anyone?
  #6 (permalink)
Old 11-26-2007, 10:26 PM
streethealer's Avatar
streethealer is starting off with a positive reputation.
What engine ya got?
__________________
Kevin
1999 F-150 4x4 4.6L 3.55 F/R
In other words.....Bone Stock
I work on people for a living
  #7 (permalink)
Old 11-26-2007, 10:46 PM
Oh sorry ... 4.6L, 202K, 3 generations, started with my dad, then me, now my youngest drives it.
I just noticed a nice step by step repair link from question two on the FAQ's - complete with pictures. Nice site you have here!
  #8 (permalink)
Old 11-27-2007, 01:17 AM
The 4.6l is an easy 10 min job. I think that you are correct saying that it is on the drivers side. The 5.4 is on the back of the intake and a bit harder to get to. Good luck..
__________________
Kevin
  #9 (permalink)
Old 11-27-2007, 01:06 PM
MaLLoF150's Avatar
well dang..how long is it for a 5.4 maybe to do this?? but i have noticed when i move my intake around it tries to idle funny again..thanx guys for the help..but one question i'm hoping to get a 02 or 03 hd for christmas or around then..do this happen a lot in the hd's also?
  #10 (permalink)
Old 07-20-2008, 09:55 AM
tapenick is starting off with a positive reputation.
Sure this is somewhere else but wanted to post answering this (old) question while the repair was fresh on my mind.
On the 5.4 as stated above the idle air controller (IAC) is on the rear of the intake. Passenger side, a few inches past the cowl.
Pop off the throttle body cover - 1 10mm bolt on the passenger side, two 10mm bolts on the driver's side.
There's a vac fitting in front of the IAC that's not necessary to remove but it's pretty aggrevating if you don't and it slips right off.
IAC removal - the bolts in mine were a little tough to get out due to the tight location. My 1/4" air ratchet just laughed and I couldn't break them loose with a 1/4" ratchet. So I resorted to a 5/16" box end with another box end 'hooked' into the open end as a cheater. Once I broke them loose the air ratchet could be used to back them almost all the way out before hitting the firewall.
The wiring connector has one of those 'push button' releases... so not too bad. Can't see at all so just have to work by feel. Suggest laying it down gently once released .... not sure how far it would go / fall if you had tension on it and let it go.
Picked up the AIC at AZ.. $44. Checked Advance, O'Rly's - a few bucks more but they didn't have it in stock.
Reassembly is pretty much just the reverse - clicked the wiring harness on, used the top bolt to 'hang' the IAC and gasket in place, lined up the bottom and started the bottom bolt. Once the bolts were started a few rounds by hand the air ratchet could be used to drive 'em home. Replace vac hose (if removed), TB cover, rock and roll.
Tom
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
