Help!!!..........License plate frame - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 11-26-2007, 12:23 PM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
Has anyone on this forum have any issues in regards to the way our front license plates are mounted? I encountered high winds over the weekend and the front plate was nearly sheared off. I only noticed it when I stopped to refuel my truck. I noticed that the only thing holding the plate was the center pivot popper.
My dilemma is I'm not entirely sure how to install the new pivots on the plate to reattach it to the truck. Is there a special tool that the dealer uses or is it something so basic I'm just not seeing it.
Any help would be appreciated.
Old 11-26-2007, 12:25 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
I couldn't figure it out either. I had the dealer remove it. I really hope you did not have any damage to the bumper due to the high winds ripping the frame off.
Old 11-26-2007, 12:31 PM
actually I do. As soon as I got home I took off the plate so I wouldn't lose it. Since the plastic frame was spinning on the front bumper I incurred small scratches on the bumper. It might be ok , but I would need to buff it down and see what I have to work with.
Old 11-26-2007, 01:28 PM
Newton007's Avatar
Newton007 Newton007 is offline
Newton007 is starting off with a positive reputation.
The frame was kind of floppy, so I used some big sheet metal screws to hold the plate and frame on and was long enough to screw through the bumper. Now it is more solid, but not what I would call great. Everything is plastic now it seems.
Old 11-26-2007, 04:24 PM
rich93cw rich93cw is offline
rich93cw is starting off with a positive reputation.
I'd use Aluminum pop rivets with backup washers.
Old 11-26-2007, 04:32 PM
crehberg's Avatar
crehberg crehberg is offline
crehberg is gaining momentum as a positive member of FTE.
No offense....but if you don't like that little cheap plastic plate frame...why don't you buy an aftermarket metal one????
Old 11-26-2007, 06:23 PM
Newton007's Avatar
It is not so much the frame as there is not much to mount it to. This plastic bumper I think is filled with foam of some sort so there is not much support for it.
The big sheet metal screws helped a lot as it screwed a ways into the foam or what ever it is in there.
You can tell I am not a fan of this plastic stuff now days.
I had a 73 T bird that had a solid bumper you use to knock down brick walls with.
One good bump on this 07 and it might just fall off.
Old 11-27-2007, 12:50 PM
IQ9 IQ9 is offline
I think there might be some confusion. The frame is the mounting bracket for the plate. We are not talking about a runner around the plate but the bracket holdng it to the vehicle.
Old 11-27-2007, 01:18 PM
Newton007's Avatar
Right, I used large / long sheet metal screws through the holes in the licence plate and the black plastic frame, into the bumper or should I say "big chunk of plastic" they call a bumper.
The large / long screws went in to the "bumper" about an inch or so.
Tags
ford, frame, frames, license, plate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
