How much fender can I trim?
I have a 2003 F250 Diesel. I want to fit bigger tires, (33" already on, fit fine with no lift). Lifting will give me more clearence to fit bigger tires, but will also raise the center of gravity. Fender trimming will give me more clearence to fit bigger tires, but won't raise the center of gravity as much. I've had 2 jeeps that have had the fenders trimmed to fit bigger tires, it seems to work great.
SO, how much can I trim my Ford's fenders? How much bigger tires could I go to with JUST a fender trimming?
Thanks!
Thanks!
Thanks!
Thanks!
thats awsome!!!!
it must be beat to chit...
How much lift do you think it takes to make a fullsize dangerous? You change the COG, and gain break over angle. That is not a bad thing. A few inches is not going to make a terrible difference. Matter of fact, approach, and departure angles will even improve, as will suspension travel. If you are running a stock spring now, you are limited to a few inches of compression, that is something that a sawz-all can't fix.
My buddy had a '01 F250 with a 6" suspension lift and 44s that was the absolute best looking SD Ive ever seen. This guy trimmed an awful lot but used bushwacker pocket flares so it was hard to tell. He copied the idea from a guy who had his truck in "Fourwheeler" magazine who did the same thing. You might be able to search Fourwheelers website for pics because my buddy has already sold the truck. By comparison it usually takes 12"+ to get 44s on a 99-04 SD. Trimming isnt a bad thing.
Originally Posted by quadzjr
and if that dont work.....grab a hammer!
and if that dont work.....grab an even bigger hammer!
Heck, bet it til it's either beautiful, or busted. Then go grab a few more beers and search out a Chevy to beat on.....
Oh, and then put some rockies on it!! (Sorry Quad, had to say it. )
Thanks!
Thanks!
it is SOOOO refreshing to hear someone ask a tire fitment question with no lift!
you'd be surprised how little you really need to trim. i have seen guys running around here with 35's on a truck identical to yours. like i tell most people... buy the tires you want first and then do what it takes to get them to fit. trim a few inches and add a leveling kit or something minimal.
just my .02
-cutts-
