Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-26-2007, 12:38 AM
mwvdub's Avatar
WYO Chapter LDR
mwvdub is gaining momentum as a positive member of FTE.
Project:10 Second F100
Nothing to do this Turkey day so my Dad and I headed out the to shop to begin the transformation of our half street/half strip 1979 F100. The front suspension has always been quite soft so we ordered DJM 3" drop deams and a set of Lakewood 90/10 Drag shocks. The rest of the front end was cleaned up and painted either Black or the brightest red rattle can available.
Before (28 years of road grime included)
http://i223.photobucket.com/albums/d...k/IMG_0381.jpg
http://i223.photobucket.com/albums/d...k/IMG_0382.jpg
http://i223.photobucket.com/albums/d...k/IMG_0401.jpg
http://i223.photobucket.com/albums/d...k/IMG_0403.jpg
And a few after shots.
http://i223.photobucket.com/albums/d...k/IMG_0410.jpg
http://i223.photobucket.com/albums/d...k/IMG_0429.jpg
http://i223.photobucket.com/albums/d...k/IMG_0431.jpg
http://i223.photobucket.com/albums/d...k/IMG_0407.jpg
Rear Suspension to be continued.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-26-2007, 12:51 AM
mwvdub's Avatar
WYO Chapter LDR
After finishing up the Front I beams and shocks on Saturday morning we turned to the rear of the truck. Removed the box a few weeks back and delivered it to a body shop to install the new Chris Alston tubs. We started be removing the gas tank, cross members, the old axle setup and all old fuel lines and wiring.
http://i223.photobucket.com/albums/d...k/IMG_0434.jpg
http://i223.photobucket.com/albums/d...k/IMG_0442.jpg
http://i223.photobucket.com/albums/d...k/IMG_0445.jpg
http://i223.photobucket.com/albums/d...k/IMG_0452.jpg
The new Ladder bar setup from Chassis works calls for a boxed frame so we started on straightening up the frame and creating templates for the boxing pieces.
http://i223.photobucket.com/albums/d...k/IMG_0466.jpg
http://i223.photobucket.com/albums/d...k/IMG_0486.jpg
http://i223.photobucket.com/albums/d...k/IMG_0477.jpg
Finally started laying out for new 2X3 crossmembers and ladder bars.
http://i223.photobucket.com/albums/d...k/IMG_0460.jpg
http://i223.photobucket.com/albums/d...k/IMG_0482.jpg
Also started prepping the new axle housing.
http://i223.photobucket.com/albums/d...k/IMG_0469.jpg
http://i223.photobucket.com/albums/d...k/IMG_0475.jpg
  #3 (permalink)
Old 11-26-2007, 12:55 AM
mwvdub's Avatar
WYO Chapter LDR
Upcoming projects include: finishing the rear suspension, installing the roll cage, finishing custom aluminum dash piece with new FRPP gauge set, carpet, new upholstery on bench seat and new 514 BBF mated to a C6.
  #4 (permalink)
Old 11-26-2007, 01:44 AM
*********- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
Thats pretty sweet... keep up the good work!
  #5 (permalink)
Old 11-26-2007, 02:22 AM
psquare7575's Avatar
psquare7575 is starting off with a positive reputation.
Those beams sure look familiar. Nice work so far.
__________________
75 H/O Project: Revival
78 Mercury Cougar XR7 523/c6/3.55:1
79 Ford F100 XLT 2WD 460/c6/3.55:1
93 Cavalier Z24 Clone
  #6 (permalink)
Old 11-26-2007, 08:15 AM
ford141's Avatar
ford141 is starting off with a positive reputation.
Quote:
X2 on that, haha. Cool project, keep us updated!
Btw, since your getting a new 514, if you need a good home for the old 472, I have a green '79 that would gladly adopt it... just kidding, haha.
__________________
Eric
ford141
05 F150 FX4, 35" Nittos on 22's, 4.56 gears, K&N FIPK, Edge Evolution, Magnaflow SIDO
79 F250 Ranger 2wd, 460 auto, 1/2 ton spindle swap, 3" DJM drop, 9" rear w/ 5" flip kit
77 F150 4x4, 35" BFG Muds, weak 351M, work in progress
03 Kawasaki Prairie with some go fast goodies
  #7 (permalink)
Old 11-26-2007, 07:33 PM
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Wow that looks so awesome keep it up
__________________
Dustin - Southern Saskatchewan Canada
My Truck:
1993 F150 XLT Reg cab Long box 351 (5.8L) E4OD 2wd 3.55 non limited slip axle factory ten hole aluminum rims
Dad's Truck:
1992 F150 XLT Supercab Short box 302 (5.0l) E4OD 2wd 3.55 non limited slip axle factory five star wheels
2006 F150 XLT Supercrew 5.5ft box XTR 5.4l 4R75E 3.73 LS 4x4
  #8 (permalink)
Old 11-26-2007, 08:15 PM
mwvdub's Avatar
WYO Chapter LDR
Wink
Ya, keeping up with your "drop and repair" thread gave me the motivation to finally install the beams. Took about a day and a half working pretty slow and steady. Truck doesn't look very low right now since the engine is out so I have to figure out a way to get about 750 punds onto the front to simulate the engine being there so I can finish the ladder bar setup. So far I have come up with a 55 gallon drum full of water, 100 lb bags of sand blast sand, 80 lb bags of quikrete, cinder blocks or some combination of those. Also waiting on new front tires that will lower it about another inch 1 1/2".
Hoping to do weekly updates as the truck is in my dads garage and I live 70 miles away. The old 460something looks something like this currently (pretty bad picture of closed valves with a 1/4" gap between the valve and the seat. Also only 7 good pistons with 6 good rods and no crankshaft or camshaft. It would make a sweet boat anchor though.
http://i223.photobucket.com/albums/d...k/IMG_0389.jpg
  #9 (permalink)
Old 11-27-2007, 11:12 AM
ford141's Avatar
Quote:
Ouch, I see why you're getting a new motor! What did the truck run on the old motor?
__________________
Eric
ford141
  #10 (permalink)
Old 11-27-2007, 07:13 PM
mwvdub's Avatar
WYO Chapter LDR
The old motor was kind of a cobbled mess of left over parts and stuff from swap meets. Stock block bored .020. stock crank, stock polished rods, cam that was built for the 514 so it idled like crap, heads ported by my dad and I when I was 16, victor intake and a demon carb. Stock C6 with manual valve body, detroit locker with 513 gears and 33X15X15 goodyear eagles. The trucks fastest time at Douglas Motorsports Park in Douglas, Wyoming was 12.89 and about 106 mph. The alltitude is 5000 feet and the density altitude is somewhere around 8000-9000 ft. In Julesburg, Colorodo along the Kansas border where the elevation is a lot closer to sea level (1500 ft maybe) the truck ran a 12.65 at 109.
  #11 (permalink)
Old 11-27-2007, 09:47 PM
ford141's Avatar
Cool, sounds pretty good for an unmatched combo. My motor is badly in need of gaskets and seals, and the C6 is slipping going into 3rd, so I'm planning to pull the combo, rebuilt the C6, and go through the motor. I've been hanging out on 460ford.com and plan to follow the formula in the FAQ section to build a budget motor capable of 425-450hp. I've had a cam laying around for a few years but I think its too big, its a Comp 270H with ~.550/570 lift and 235/240 duration. I think I may sell it for a smaller one that will work better with stock ported heads and give me enough vacuum to be streetable. My truck ran a best of 15.60 last summer at Keystone Raceway here in PA. Motor was bone stock besides a 68-72 timing chain set and dual exhaust. Tranny left in drive (and slipping in 3rd), slight spin from the 235/70/15 street radial tires, bog on 4-barrel opening. It was at least a baseline run and I figure I shouldn't have much problem improving on that... Anyway, I'm done rambling... back to the regularly scheduled thread.
Keep us updated on progress
__________________
Eric
ford141
  #12 (permalink)
Old 11-28-2007, 01:10 AM
mwvdub's Avatar
WYO Chapter LDR
I also follow along on 460ford.com and have learned that there is actually quite a bit of interest racing the 385 series. I always thought I was crazy running a BBF but feel better about it now.
When I started racing we ran in the 15 also. Consistently ran 15.15 and were killer in the street class becuase we never had to change the dial-in and could concentrate on the lights. Six years and several thousand dollars later I am hoping for 10's or I am buying a NOS kit with my tax return.
Spent some time tonight welding up holes in the frame so it no longer looks like swiss cheese. Sending the 9" with my dad to denver on friday to get narrowed 9". I am planning in have it 5.5 inches in the left side and 3.5 inches on the right side so the pinion and driveshaft will be centered. Also ordered some adjustable jackstands to set up the pinion angle and axle height. Bought some Powder coat to coat the axle housing, shifter, dash piece when it gets built and the ladder bar pieces not already coated.
  #13 (permalink)
Old 11-28-2007, 01:51 AM
Who are both of you on 460ford.com?
I am.. Psquare75. lol
__________________
  #14 (permalink)
Old 11-28-2007, 07:52 AM
ford141's Avatar
I am ford141, same as I am on every forum that I join. I haven't posted very much on there since I mostly just go to read up on info. I'm still new to building these, so I don't have a lot to add to the wealth of info on there. My neighbor got me hooked on the 385's, and after I realized how much power these things are capable of without much work, I've never looked back.
__________________
Eric
ford141
  #15 (permalink)
Old 11-28-2007, 08:34 PM
mwvdub's Avatar
WYO Chapter LDR
I am 514wyo on 460ford.com and as ford141 stated, I am also a newbie to building 385 series motors. I have always used stock parts but can't seem to keep rods for very long so I have been lurking on 460ford to figure out a good combo for the new 514.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
