Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-25-2007, 11:34 PM
95XL 95XL is offline
Garage is empty, add now
95XL is starting off with a positive reputation.
Flathead Six Electronic Ignition
Hey everybody, I have some questions about a first generation flat head 226. My dad and I have an old Toro tractor with one in it. I was wondering if anybody knows where I can find, or if they even make electronic ignition kits for these engines. If so, where can I find one? It doesn't have to be a performance one, just one to get rid of the points and replace the distributor.
Thanks for any help.
  #2 (permalink)
Old 11-27-2007, 02:57 PM
rswhitmore rswhitmore is offline
rswhitmore is starting off with a positive reputation.
Try Pertronix. Their 2007 Catalog on their Website indicates they have systems for Ford Six engines back to 1949. You may be able to use one of those in your distributor, but it will only eliminate the points, condenser etc., not replace the whole distributor.
  #3 (permalink)
Old 11-27-2007, 03:32 PM
That would be great, all I'm really looking to replace is the points, the rest can stay. Thanks.
If anybody else has more tips, keep them coming, I'm always open to more suggestions.
  #4 (permalink)
Old 11-27-2007, 03:44 PM
I have a question about that Pertronix ignition...
I'm pretty sure the flathead in this tractor is a G block, or the earliest of the two flathead blocks. (I come to this conclusion because, it has a tag on the engine that says it was re-built in 1952).
My question is, does the older block have the same timing and firing order as the newer model? So, would the electronic ignition work from a 1949 flathead?
  #5 (permalink)
Old 11-27-2007, 04:03 PM
I don't know if the G series and the H series distributors are the same or not. They are at a different location on the engine, but may be the same distributor. Someone on the Forum should be able to answer this question. The firing order should be the same, but it wouldn't matter if it was different as long as the top end of the distributor was the same.
  #6 (permalink)
Old 11-27-2007, 07:03 PM
46lash 46lash is offline
46lash is starting off with a positive reputation.
I may be wrong but doesn't the G have the distibutor on the front of the engine and the H on the left side.
  #7 (permalink)
Old 11-27-2007, 07:06 PM
I may be wrong but doesn't the G have the distibutor on the front of the engine with the square coil as an intregal part of it and the H is on the left side with the seperate round can coil.
  #8 (permalink)
Old 11-29-2007, 02:31 PM
Judging by that description, I must have a H block, because it has a round can coil, and the distributor is on the left side, not the front. So, does that mean that the petronix ignition would definitely work?
  #9 (permalink)
Old 11-29-2007, 04:27 PM
Quote:
If it's an H engine(made through at least 51) I think there is a good chance it will work, but you are going to have to talk to Pertronix yourself and decide.
  #10 (permalink)
Old 02-07-2008, 04:15 PM
effie_man's Avatar
effie_man effie_man is offline
1953 Ford F-100
effie_man is gaining momentum as a positive member of FTE.
i just installed a petronix on my H block. with coil and voltage reg also took an hour and a half
__________________
Chris
1953 Ford F100 Custom Cab
1950 Mercury Monarch
2004 Ford F150 STX 4x4
Tags
1950, 1952, coil, conversion, convert, e150, electronic, flat, flathead, ford, head, ignition, inline, kit, toro, truck, v8, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
