11-25-2007, 07:04 PM
2004 F150 4x4 Supercrew Engine won't start...Need Help!
My truck sat for about 3 days in the cold (about 35 degrees at night.) Turned ignition key and acted like a drained battery. (Think I left the radio on or something) Tried to jump with another small truck battery, but would not get enough juice to do the job. Engine would turn but no ignition.
Then, I hooked up a "Fast Engine crank /Slow trickel charge" Cahrger that I plufgged into the garage electrical socket, but the engine wouldn't even turn over this time. The instrument panel said "Engine Sensor Error" and "Check Engine Temperature" I was low on Antifreeze, so I filled it back up to correct level. Still no engine power.
Now, The head and tail lights came on with the battery charger on only, even though the switch was off! Prior to this stage of the process, I had no spark when connecting the battery charger to the Truck battery terminals. Now I get a spark when making contact.
Still, no engine turn and now no intrument panel lights. I now here a clicking sound coming from behind the truck bed. It sounds like it is coming from the drivers side of the truck between the bed and the rear passenger door. I think that may be where a fuel pump is located?
I need help to determine what is wrong and how to go about fixing it. Any help would be much appreciated.
