Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-25-2007, 11:47 AM
rokhedjo rokhedjo is offline
Garage is empty, add now
rokhedjo is starting off with a positive reputation.
Question best air filter setup, V-10
any opnions on the best/ most sconomical/ best performance, etc.,etc.......
  #2 (permalink)
Old 12-30-2007, 11:22 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
I know the Outlaw Power CAI is a quality unit on my 5.4L.
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 01-02-2008, 04:46 PM
wwb wwb is offline
wwb is starting off with a positive reputation.
Aside from full-throttle operation at the dragstrip, there is very little to be gained with an aftermarket intake system on a gasoline engine. Under normal operation, like 25% throttle or so, your throttle restricts the airflow FAR more than the intake system..... to the point that any reduction in intake restriction would be trivial or less.
A diesel is a different story.
  #4 (permalink)
Old 01-02-2008, 05:15 PM
Some do filter air better than others I am sure, I guess a K&N filkter in the stock box will do.
__________________
2000 Excursion 4x4 v-10 3 inch lift,Bilstein shocks,F-250 chrome grill,Helwig rear sway bar,Gibson exhaust,K&N filter, ICC lights, and repaired spark plug hole !
  #5 (permalink)
Old 01-02-2008, 11:58 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
There has been a debate as long as I can remember, but a replacement K&N filter will not "filter" any better than a OEM Motorcraft filter. The only benefit of using a K&N (and such) is that it is re-usable.
Be careful when cleaning...as the oil based filters tend to dirty the MAF sensor causing poor performance.
IMO...the dry type filters are better. Here is what I recommend...
advanced FLOW engineering
http://www.afefilters.com/
OE Replacement Filter with Pro-Dry S
Ford Trucks (99-04) (gas)
Part Number: 11-10004
MSRP: $45.49
UPC: 80295911006
Shipping Weight: 2 lbs
Hope this helps...
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Tags
2003, aftermarket, air, dirty, duty, f150, filter, filters, ford, harley, heavy, intake, setup, truck, trucks, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
