ABS light due to speed sensor? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-25-2007, 11:03 AM
Jack_99V10 Jack_99V10 is offline
Jack_99V10 is starting off with a positive reputation.
I just purchased a 2000 F350 7.3L CC LB SRW with 120k on the clock. During the testrdrive the ABS light was on... no biggie, I got a steal on the truck. Then I noticed sometimes when I turn the truck on, the light is off, but once I get rolling the light turns on and stays on. In the summer there are 39.5 IROKS on it... my "crappy weather" tires are 37" TSLs and my winter tires are tiny Hakka snows. They are like 29" tall or something silly. Either way, the light would trip immediately or stay on.
During my inspection I had my buddy plug in his SnapOn scanner, and it registered as the speed sensor in the axle.
My speedo works. It isn't accurate due to the larger tires, but it moves just like any speedo. It is sensing speed, just not enough
Would replacing the speed sensor solve my problems? Is it really the speed sensor? If it was, wouldn't the speedo be acting up as well?
I would also like to correct the speedo, but I haven't been able to justify spending $200 for just that purpose.
Any help would be appreciated.
Old 11-25-2007, 11:06 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Yes, a VSS sensor problem will cause an ABS light, although that is usually accompanied by speedometer problems.
As a first step, remove the VSS sensor and clean it. See if that doesn't help.
Old 11-25-2007, 11:24 AM
Thanks. it is right on top of the diff right?
Old 11-25-2007, 11:25 AM
redford's Avatar
10-4 on the location
Old 11-25-2007, 12:27 PM
Before I go out there and soak it with WD40, what would you recommend?
Old 11-25-2007, 01:45 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
[QUOTE=redford]Yes, a VSS sensor problem will cause an ABS light, although that is usually accompanied by speedometer problems.
QUOTE]
I had a VSS failier and speedometer worked fine
Old 11-26-2007, 05:58 AM
glsurratt's Avatar
glsurratt glsurratt is offline
glsurratt is gaining momentum as a positive member of FTE.
Another indicator combined with the ABS light would be whether or not your cruise control still works properly. Mine would engage but after a few minutes, it would disengage as if the engine had stalled and then re-engage with a kick in the pants acceleration to get back up to speed.
Old 11-26-2007, 10:13 PM
Cruise works fine.
Is WD-40 ok to clean it?
Old 11-26-2007, 10:19 PM
rbaker6336's Avatar
Quote:
Originally Posted by glsurratt
Another indicator combined with the ABS light would be whether or not your cruise control still works properly. .
VSS sensor don't always affect cruise,occaisionally wound affect speedometer but would work again with restart
Old 11-27-2007, 09:11 AM
fordboy2's Avatar
fordboy2 fordboy2 is online now
fordboy2 is gaining momentum as a positive member of FTE.
Like someone else said it may just need to be cleaned, It is basically just a magnet and gets metal shavings on it and gives funny readings. I myself would just replace it as they are not all that expensive and then you would know you should have a goodone in the there.
Old 11-28-2007, 09:10 PM
Barney674 Barney674 is offline
Barney674 is starting off with a positive reputation.
1. Your ABS/ VSS can be removed and cleaned with just a clean rag, no need for wd-40 or any other solvent, also carefully clean out the hole on top of the differential, lift the vehicle (place in neutral) and check the sprocket wheel inside the pumpkin for possible missing teeth or to see if it is loose.
2. The VSS (part # F85F-9E731-AA) can also be tested with an ohms meter, it should measure ~1.9 K-ohm or higher (lower than 1.9 requires replacement).
3. The VSS is a hall-effect sensor, connect a volt meter to the sensor connector and wave a piece of metal (pair of pliers or flat metal) about a half inch away from the sensor, and you will consistently see a variation in voltage, if no movement on the volt meter is observed, replace the sensor.
4. You also have the two front wheel ABS sensors, try cleaning them first, and carefully reinstalling them.
5. When the VSS sensor is malfunctioning, the PCM may try to get input from the TSS (turbine speed sensor, top of the transmission), and as it turns out, the same return wire is used by the OSS (output speed sensor, tail end of transmission), check these two sensors also, clean them and test them (1.10 K-ohm or higher). These are also Hall Effect sensors, so check for voltage as described in paragraph 3 above.
6. Pay attention to see if your ABS light blinks when you start the vehicle, just before it stays solid. If this is happening, count the number of blinks, as this is actually a code and the blinking means the vehicle is trying to communicate with you.
7. Last, if nothing above corrected the problem, I would start tracing RFI (radio frequency interference), one sure area is usually your fuel pump (wires running along side VSS wiring. ABS/VSS wiring is routed directly to the ABS module.
I hope this information works for you.
Old 11-29-2007, 11:03 AM
edjunior's Avatar
edjunior edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
Dang...if this don't fix you up, you can't be fixed!! Nice post!
Old 11-29-2007, 11:38 AM
GregN's Avatar
GregN GregN is offline
GregN is gaining momentum as a positive member of FTE.
I guess there really isn't anything else anyone can say on that subject! Wow! Nice post.
Old 11-29-2007, 11:46 AM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
HOLY CRAP!!!! IT'S AREA 51! TRANSFORMERS!!!!!
What he said. There are two "speed sensors" though that can be confused at the parts store. They don't look the same but they are listed almost the same. The one on the rear diff is listed as the "ABS speed sensor"....the one on the tranny is listed as the "Speed sensor" The rear one is the cheapest and easiest to replace...about $12.
Old 11-29-2007, 06:46 PM
Thanks for all the help.
Barney... that was quite an entrance. Welcome!
abs code c1236 05F250DSL 1999 to 2016 Super Duty 0 03-29-2015 01:24 AM
Edge Evolution CS tjcprop Computer Chips & Tuners 0 06-28-2014 07:46 AM
speedometer problem reaper75032 1999 to 2016 Super Duty 15 12-28-2012 01:28 PM
Setting the speedometer rmrichards949 Excursion - King of SUVs 11 09-03-2011 09:11 PM
VSS Sensor(FIXS ALOT) John311t 1999 - 2003 7.3L Power Stroke Diesel 3 06-10-2007 05:33 PM
Tags
01, 06, 1999, 2000, abs, f250, f350, ford, front, input, light, problem, sensor, speed, turbine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
