Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-25-2007, 08:57 AM
gistecknician gistecknician is offline
gistecknician is gaining momentum as a positive member of FTE.
Factory Navigation Use While In Motion (w/pics)
I found out how to do this on my 2004 Expedition EB from a posting in the Expedition & Navigator forum. The person that orginally posting the instructions on how to do this was bridge, and elder member here on on the Ford Forums. I am going to list a combo of his/my instructions along with the pics I took while doing this mod on my vehicle.
1. To remove the black dashboard trim, remove the two screws above the instrument cluster. You will be tempted to just bend the trim piece enough to get at the headunit screws but the headunit must come out of the dash anyway.
2. Once the instument panel has been removed you will see two bolts below the radio that hold it in place. Remove these two bolts and the radio will come right out.
3. Once out (or out far enough to get at the harness), looking down at the back of the HU you will see a harness with only 4 wires on the right side. There will be a black wire with a white stripe, that's the VSS wire.
  • Push back the cloth material wrapped around the wires and cut the wire a few inches from the harness.
  • Strip the wires and crimped on two 20ga crimp connectors (the red ones).
  • Prepared your switch by soldering about a foot of wire onto each pole. I used a simple STDP switch, but I would suggest mounting a black push button switch somewhere near the HU. Not a momentary switch. You want one that will switch between on and off and stay either on or off.
  • Crimp the switch wires into the VSS wire crimps you place on the VSS wire.
4. Mount your switch where ever you like. (I mounted mine under the steering column, out of sight but functional) Done deal!
As you can see in this pic, I am going 30 MPH and the Nav Options are still available. It works!
Well thats all folks, once again I would like to thank bridge for the excellent instructions that he provided. Without them I would not have know where to start on this mod.
  #2 (permalink)
Old 11-25-2007, 10:43 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE. Beerstalker has a very good reputation on FTE. Beerstalker has a very good reputation on FTE.
Good instructions and pics. I should have known Ford would do it the easy way and just use the VSS wire to tell the unit when the truck is in motion (most aftermarket units tap into the parking brake wire and you have to depress the parking brake in order for the screen to show movies or allow navigation changes).
This should work in the Super Duty trucks as well, although I believe the VSS wire is a grey wire with black stripe in them.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #3 (permalink)
Old 11-25-2007, 10:52 PM
chucks_net's Avatar
chucks_net chucks_net is offline
chucks_net is new and has a neutral reputation at this point.
Great write up
I don't have built in nav soplease excuse my lack of knowledge on this subject -you mean if you are driving you can't use nav?
Why would you ever need to use the switch?
  #4 (permalink)
Old 11-25-2007, 11:46 PM
You cannot use the touchscreen to change destination, route, etc. when the vehicle is moving. They do not want the driver trying to mess with the navigation while driving down the road. However, if you have someone else in the vehicle it is very annoying that they can't make changes for you, so many people have sought out ways to override this kind of safety feature.
__________________
  #5 (permalink)
Old 11-26-2007, 06:28 AM
Ford puts this great tool in the truck, with all of these great features (buisness directory especially) and then takes away the ability of your "navigator" (historically the passenger) to utilize them when you need them most.....While You Are In Motion!
I can at least understand the need of aftermarket companies to put this type of restriction on their units due to the fact that 99.9% of them are also DVD players, and it is illegal in most places to watch movies while operating a motor vehicle, but Fords Navigation unit is not capable of playing DVD movies in its factory unmodified state...so why the restriction??
  #6 (permalink)
Old 11-26-2007, 01:03 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
i will be adding this to the tech folder at the top. props!
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #7 (permalink)
Old 11-26-2007, 07:01 PM
No Prob, always willing to help!
I am also waiting on a 8000k HID kit, I will be sure to take pics every step of the way and post that here for another tech forum (if it isn't here already)
This is probably the most active forum I have ever been on, I look forward to a member for a looong time.
  #8 (permalink)
Old 11-26-2007, 07:20 PM
fordboy_52's Avatar
ok, its up there. good job! +1!
Matt
__________________
  #9 (permalink)
Old 12-06-2007, 12:57 PM
Jody7 Jody7 is offline
Jody7 is starting off with a positive reputation.
Sorry to be skeptical, will this mod work on my 2008 F350 nav system??
  #10 (permalink)
Old 12-06-2007, 09:06 PM
It should, but you need to figure out what wire the VSS is. I know in the 05-07 trucks it is a grey wire with black stripe, I am not sure about the 2008 though.
__________________
  #11 (permalink)
Old 12-07-2007, 11:16 AM
Thank you Beerstalker
Anyone know how I comfirm the wire is the same (grey with black stripe) or is another color in the 2008's???
  #12 (permalink)
Old 12-11-2007, 01:59 PM
drbalazo drbalazo is offline
drbalazo is starting off with a positive reputation.
Jody7:
try this link:
http://www.avic411.com/forum/viewtopic.php?t=9921
  #13 (permalink)
Old 12-11-2007, 06:23 PM
According to this link the VSS wire should be in pin 14 of the 24 pin connector, next to the ground wire. I am not sure what color that wire is in the 2008, or if it is the correct wire, but it is where I would start.
http://www.discountcarstereo.com/pdf/frd04-aux.pdf
__________________
  #14 (permalink)
Old 04-13-2008, 05:49 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
Good info gisteck and Beer. I hope to use this info by the end of the month
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
10 Escape XLT
This isn't your father in law's Buick. Step back
and no one gets hurt!
  #15 (permalink)
Old 04-13-2008, 09:39 PM
soxfan81's Avatar
soxfan81 soxfan81 is offline
soxfan81 is starting off with a positive reputation.
good info gave you some rep for this one. thanks
__________________
New England Chapter
Florida Chapter
05 XLT Supercrew
06 E250 (Work Van)
Tags
08 , 09 , 2000 , buy , color , driving , f150 , factory , ford , locating , motion , nav , navigation , unit , vss , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
