Hello all,
I've been monitoring this board and wanted to see if this will apply to my Expy as well.
Does anyone know if this setup will work on a 2007 Expy? If it does anyone have instructions on how to remove the Nav out of my truck? Is the canbus 34 pin connector the same on all expy's or are they different?
Has anyone figured this out yet for the 08 Super duty? I thought I had the problem licked, I cut the grey/orange wire for the CAN bus and you lose the radio all together. I'm still trying to find an enable code. Don't want to keep cutting wires if I don't have to. Any info would be great. Thanks
__________________
08 F350 SRW KR CC LB 4X4 Dark Copper Metallic V-10/Torque Shift, Loaded UP!!
10 Escape XLT This isn't your father in law's Buick. Step back
and no one gets hurt!
I am wondering if anybody has accomplished this fix on a 2008 f450 super duty ? I am very dissapointed with the nav system in comparison to others I have used . there is no ability to spell the name of a ocation that you are looking for eg a store or restaurant etc. I was curious if there is an after market software provider that gives us usfull tools . any responses appreciated
The vss is the e brake on aftermarket stereo's. And you override that with a ground switch also... if you need help finding your vss wire on your existing gps/dvd go to your local radio install shop they do this for me for free plenty times and they even print me what wire is what... hope you have luck nice install on the switch just like a pro
Please check the Super Duty Forum. I have just posted instructions regarding this topic. Good luck. If you have any questions, pm me.
__________________
__________________
So I got my hands on a navigation unit out of a 07 f150 and I want to install into my 07 f350.. I plugled it in steering wheel controls work it turs on radion works everything works but the gps. when I bought it it did not come with a antenna for the gps cause there built into the roof on the f150 does anyone know where or if i can use another antenna. Ford wants 500$$ for the antenna and its a special order so you know how that goes.. thanks
Caddy, I have been told the instructions don't work on an 09, but I personally have never tried
__________________
__________________
I have an 03 Expedition, and get the restriction even wish passengers, so I want to bypass the whole thing. Here is my question.
The OP talks about putting a switch in-line. My question is:
Is there any reason that you would ever want to turn that back on once it is off??? If I just simply cut the wire, and cap the ends, what is the draw back??? What functionality (if any) would I lose???
I wanted to PM the OP author, but even though everything says I can, I can't... So if anyone can help me here, would be much appreciated.
