Help with installing my stock air filter!? - Ford Truck Enthusiasts Forums
Old 11-24-2007, 04:35 PM
wgm114 wgm114 is offline
wgm114 is starting off with a positive reputation.
On my 2001 5.4L F250 air filter, there is an arrow printed on the back of the rubber circular edge. It says "align arrow with notch" then points awkwardly toward the edge of the rubber circle. I thought maybe they meant the top notch of the plastic shroud but when I go to join the back part with the front part and clamp them, there is another picture showing "arrow placement" on the black plastic piece that mashes down on the rubber backing which is attached to the intake hose.
What arrow should match what notch? Furthermore, why? And does it matter which directioin the circular filter is installed with regard to rotation?
Help!
Old 12-29-2007, 02:42 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
I've never heard of issues with regards to which direction they are installed. As a matter of fact on several applications I've used it to my advantage, ever couple thousand miles changing the direction because it tends to load up in one area if you don't.
putting the Iginition back in for the 68 F250 nathan328 1967 - 1972 F-100 & Larger F-Series Trucks 2 10-19-2016 02:48 PM
Tow Mirrors, adding blinker "arrow" LEDs behind mirror (modification) JohnnyAirtime Excursion - King of SUVs 2 09-12-2013 11:58 PM
How to install T-stat? bama29fan 1999 - 2003 7.3L Power Stroke Diesel 12 06-20-2010 11:53 AM
Econoline glass seals Ole' Green Ranchero & 1961 - 1967 Econoline 12 08-22-2007 03:04 PM
Installing Pistons jazzy66 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 02-07-2005 01:02 PM
Tags
54, air, filter, installing, matter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
