Gas engine oil pres. gauge:
It is an electric or mechanical gauge? If it's electric there could be something wrong with the sending unit........If it were me I'd get a good mechanical gauge on there and see what the oil pressure is actually doing at idle.......obviously your oil pressure increases (or decreases) as engine speed increases (or decreases, respectively).......
My $.02
-Jake
My $.02
-Jake
My $.02
-Jake
My $.02
-Jake
additional info.
Have checked the actual oil pressure and it is fine. Replaced the sending unit and the results were that it reversed the reading. When idle it reads hi and cruising it reads low. The oil is changed regularly with premium oil.
Glad to hear everything is OK......you don't need those kind of problems. It's a bit weird to me that it reads higher at idle than going down the road.......I guess I just don't understand how that would be possible.....(idle=low rpm=oil pump pumping less........cruise=higher rpm=oil pump pumping more.....). Come to think of it, the "oil pressure gauge" in my '98 never moves at all, it's more like an idiot light with a picture. I know how much the pressure in my '69 changes (just over 80 when cold, 20 at hot idle, 55-60 at cruise).
-Jake
-Jake
