Dripping leak while cold - Ford Truck Enthusiasts Forums
Old 11-24-2007, 01:07 PM
MallardSlayer07's Avatar
MallardSlayer07 MallardSlayer07 is offline
MallardSlayer07 is starting off with a positive reputation.
I have a dripping leak coming out of what looks like a sensor of some sort on the side of the the fuel pressure regulator which is black and has one red wire going into the plug. Any information on what its called and where i should go get one would be great guys. Thanks alot -Chris
Old 11-24-2007, 01:35 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
Most likely the fuel restriction sensor,, If so you can replace it with a 1/8 pipe plug.....
Look... here... which one?...
Old 12-01-2007, 12:01 PM
Definitely the fuel restriction sensor! I already did the plug! Thanks so much for the help! -Chris
Drip, drip, drip Diesel Royson12 1994.5 - 1997 7.3L Power Stroke Diesel 6 01-19-2013 09:00 AM
WHAT THE HECK AM I DOING WRONG?????? Franko72 1999 - 2003 7.3L Power Stroke Diesel 23 11-22-2012 02:17 PM
small fuel bown drain line leak 2003chromefatboy 1999 - 2003 7.3L Power Stroke Diesel 2 09-13-2012 03:12 PM
Fuel Filter Housing Leaking chris86924 1999 - 2003 7.3L Power Stroke Diesel 5 01-17-2012 08:29 PM
ac/heat blower leaking water..? chris_h5 1987 - 1996 F150 & Larger F-Series Trucks 8 11-22-2006 02:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
