I have an '02 and the blend door acutuator has broken off a pin from the cable to the door itself. Anyone know if this is a dealer item only? Or is there a fix remedy? This only would happen at the beginning of winter when you need the heat to work!! Thanks in advance for any help......
__________________
Remember folks mash it to the floor until you hear it whining! It's a Ford!!
