2007 sport trac trans/no dipstick???? - Ford Truck Enthusiasts Forums
Old 11-24-2007, 12:41 AM
02sd 02sd is offline
02sd is starting off with a positive reputation.
Question 2007 sport trac trans/no dipstick????
<TABLE><TBODY><TR><TD vAlign=top width="100%">I have a 2007 sport trac 4x4 with the 4.0 engine and I need to fill the trans with fluid as there was some collision damage and I need to change the trans cooler as well as lines, what fluid does this truck use and how do I refill the fluid, sounds like you refill through the pan drain plug as there isn't a dipstick/tube???? Thanks for any info that some one can give me.
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->
Old 11-24-2007, 12:45 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
5R55N/5R55W
Fluid Check Procedure:
Drive vehicle until transmission is at operating temperature. Raise vehicle on hoist. Make SURE it is level. With the transmission in Park and the engine idling, remove Oil level check plug from bottom center of transmission pan as shown in Figure 1. (It is the allen head plug in the center of the drain plug. HOLD THE DRAIN PLUG WITH A WRENCH TO PREVENT LOOSENING IT!) When full, fluid should just trickle out this hole.
Fluid Fill Procedure:
The fill plug is located in the extension housing (see Figure 2) on the 5R55N and toward the back of the case on the passenger side (see Figure 3) on the 5R55W. It is filled here BUT checked as shown above in the Fluid Check Procedure.
NOTICE!
These transmissions require Mercon V fluid
Figure 1
Figure 2
Figure 3
Old 11-24-2007, 09:42 AM
thanks for the info, that will do the trick
Old 03-27-2013, 03:34 PM
sirjr999 sirjr999 is offline
sirjr999 is starting off with a positive reputation.
Would you have the 5R55S diagram?
These are great pictures. Would you have the diagrams for the 5R55S transmission? I have a '08 Sport Trac with this transmission and I need to change the fluid and filter. I've never done this on a vehicle that does not have a dipstick, so I have no clue where the fill plug is located, what type of plug it is, torx, allen or hex head and how I can access it to fill the transmission after the drain.
Thank you.
Old 03-28-2013, 10:10 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
You don't need a diagram for the 5R55S, all these are setup up the same way and are filled on the same principle.
Old 03-28-2013, 10:26 AM
Thank you for the information. Tomorrow, I'm changing the rear differential fluid so I'll be able to search for the fill plug on my transmission when I'm under the truck. I just want to be 100% sure of the fill plug location before I drain the transmission.
Old 03-30-2013, 03:21 AM
jdfromct jdfromct is offline
jdfromct is starting off with a positive reputation.
I have a 05 sport trac and notice that the dipstick for the tranny is hidden pretty l good, on my 4.0 it is located underneath the upper radiator hose, might help ya out
Old 03-30-2013, 01:58 PM
Changed the rear differential fluid. This was straight forward; drain plug, fill plug. Did not even have to remove differential cover. Unfortunately, the transmission does not have a fill plug, much less a dipstick. Going to have to see if some company makes an after market transmission fluid fill pump tool.
Thanks for the post.
Old 12-19-2015, 06:05 PM
Carl Liccardi Carl Liccardi is offline
Carl Liccardi is starting off with a positive reputation.
The figure 1,2,3 pics are no longer available here is there anyway for me to see them?
Old 12-21-2015, 04:29 PM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
Hey Carl. Welcome to FTE!
Here are pictures showing the check plug and fill plug for the 5R55N transmission.
If these are not what you need, just shout out and we'll see what we can do.
Check Engine Light LostMayhem Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 6 01-09-2008 01:17 AM
Resistor wire those70'sfords Electrical Systems/Wiring 5 12-16-2007 07:32 PM
Truck beeps 5 times volcom_inc 1999 - 2003 7.3L Power Stroke Diesel 8 12-08-2007 04:38 PM
Repost to correct forum. Roger Davis 1994.5 - 1997 7.3L Power Stroke Diesel 7 11-23-2007 04:21 PM
Towing with Superchip? Help!! sheranian 1999 - 2003 7.3L Power Stroke Diesel 15 09-18-2007 11:12 PM
Tags
07, 2007, 2008, check, dipstick, fill, filling, fluid, ford, mountaineer, mountaineerhow, sport, trac, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
