Adjustable Peddles
I am actually working on that on a 04. I have the mechanical parts. Got them used for $50.00, but the two pedal assemblies are available from Ford. Retail can be pretty steep, but maybe you can find a parts guy to give you a break. I got the color matched dash surround and switch from my friendly Ford parts guy.
The bigest problem I found is in the wiring. If you look up under the dash above the pedal support you will find a grey 2 wire connector with a red and white wire in it. This is the motor feed. I think all the trucks have it. The big problem is in the 14401 main wiring harness. This is the switch feed to the dash switch. The easiest way to see if you have it is to remove the lower dash panel under the steering wheel. Then remove the lower screws for the dash surround (the part that surrounds the gauge cluster, not the whole dash). You won't have to pull it off, just move it out enough to look behind it. If you see on the left side even with the steering wheel a multi-wire plug (should have red,white,blk, blk-ltblue,purp) plugged into the back of the surround panel in the same spot as the switch then you are pre-wired and the install is plug and play. If not (like mine) then you either have to intall an whole new 14401 main dash harness or run the wires individualy. The '04 heritage and older trucks have the prewire. I found one in a wrecking yard and cut out the switch plug and part of the harness to make the connections. It will probably be a project so I am waiting until I can let the truck sit a few days to a week.
When I do it, I will take photos and post them.
It is do-able, but like everyhting else how much $$ and time do you have.
