You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
there are lots of plans out there for appleseed style reactors, but I hear several people are using mechanical mixing instead of pumps, and not using water washing, but using a drying agent. (can't remember the name, senior moment... used in diapers) supposedly higher quality Biodiesel is obtained. Any ideas where I can find plans?
thanks
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
The easiest way is to get a 55 gallon drum, weld a galvanized pipe fitting in the bottom, screw in a pvc valve, then you can buy or build a 55 gallon drum mixer. I built mine out of an old greenhouse fan. I took the fan, cut the actual fan off, extened the shaft, cut the fan blades down to about 6 inch diameter, and set the whole deal over in a drum, instant biodiesel reactor. Total cost, less than $50 in the whole deal.
The dry method is called magnesol. You will need to use 2 percent by weight unless you evap the methanol and then your down to 1 percent per weight. You will need to pump the bio off the top in order to leave the heavy moisture ladden magnesol on the bottom and dump out later.
__________________
585,000+ miles on original engine. Goldie 00 F-350
