Oil Temp or Water temp? - Ford Truck Enthusiasts Forums
Old 11-22-2007, 07:12 PM
John - NNY John - NNY is offline
John - NNY is starting off with a positive reputation.
I am looking to get two additional gauges to monitor the temps on my 337 ci flathead engine. One will be a more accurate Oil Pressure Gauge than stock. The second will be a temperature gauge. Should I go with an Oil Temp gauge or a Coolant Temp Gauge? Why would coolant temps be more imprtant than oil temp or visa-versa. I start with about 32 psi oil pressure cold. After about 15-20 minutes driving, my oil pressure slowly drops to critical levels. I'm thinking the oil is getting too hot and thinning the oil. The radiator has not been boiling over.
The new gauges will be mounted on a panel below the dash - exact location not yet determined.
John
NNY
1948 F-7
Old 11-22-2007, 11:18 PM
rswhitmore rswhitmore is offline
rswhitmore is gaining momentum as a positive member of FTE.
If you are not running 20W50 oil, then you should start using it in your engine. Also a quart of Lucas Oil Stabilizer wouldn't hurt. As for the temperature gauge, I would go for a good water temperature gauge. Excessive enine heat will show up in the coolant first. The oil takes longer to heat up, so the water temperature gauge will give you an earlier warning of an engine overheat condition.
Oil in Cooling System '00 5.4L SD friscofordguy 1999 to 2016 Super Duty 0 01-26-2009 07:20 AM
ESP luber and Oilguard integrated install? thedaddycat Oil & Lubrication 1 02-27-2008 07:12 AM
loss of power under trailer load fuddy 1999 - 2003 7.3L Power Stroke Diesel 5 08-26-2007 03:08 PM
230 degree tranny temp on the freeway? BJB6521 1999 to 2016 Super Duty 18 07-19-2007 12:00 AM
6.9 Diesel temps and performance? atcboss Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-31-2007 08:27 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
390, diesel, engine, excursion, fe, flathead, ford, gage, is, oil, temp, temperature, tempiture, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
