'93 5.0 mustang engine into my '94 bronco
#31
#33
Ok- motor is in and will fire up, we have had it running twice. Not for extended amounts, maybe 30 seconds or so apiece. Tries now to fire up- (everything is now completely rassembeled and topped off with fluids) but just can't quite seem to get it. I was trying to start it so as to belch the air out of the cooling system, and fine tune the timing. Just an odd thought I tried the later firing order- way worse. So I know that's not it. We dropped the dizzy in at tdc with it pointing to number one on the cap. It was dead on perfect- I won't be convinced otherwise. We put a timing chain in it and had not turned the motor over at all. The two times it ran before I had used the wear spots for the hold down bolt for a good starting point, but that was the old motor (newer firing order). Someone left the key on acces. all night, and 94Nichols had to go to work, so we put the charger on the battery and quit. I thought it would be a good time to throw up a post and see if anyone else has any ideas? I do not know the newer motors at all- I know how to work on the pre-computer, carbed stuff. I am reasonably sure that every thing got reassembled the way it came apart, that which needed repair got it. Anyone?
#34
Well now- I guess I'm the stupid one. We got it to run and idle on it's own. Not very well, but on it's own. Checked the timing- 10 degress BTDC with the spout unplugged. Checked for vacuum leaks with a can of ether-none. Ah-what the hell-try that other firing order and see what happens. purs like a kitten. WTF!?!?!? 93 mustang motor should have the earlier firing order, but it doesn't. Even wierder, why would it run on the earlier firing order but not even close on the later firing order when we fired it up the first time? Oh well- never look a gift horse in the mouth I guess. Thanks to all who helped!
#35
#36
thanks guys. and no, we left the injectors. i think they changed the firing order in mid '94. i think mine was an early 94 with the early 302/351 firing order. so it makes sense now as to why the firing orders are the same for my old/new motor. it runs and sounds great now! cfrives told me haas an idea to get some more power out of it today. he wouldnt tell me what, but i hope it works. im thinking about upgrades now. what is the most bang for my buck for low-end torque? cold air intake? headers? any i deas are welcome. thanks again guys!
#37
I wanted to bump up his timing just a little bit for a little more oomph. I didn't want him to do it without my help. This is his first motor whereas I have done a few. I bumped up the timing on my 5.8 HO but it also has a cam, intake, dual exhaust, and the carb has been tweaked a little too. I figured that his would be ok around 14, but we played with it and drove it and left it at 18. It runs really good, no pinging or popping at all. The other thing I was worried about is when you bump up the timing, especially that much, it can make the motor crank slow and be a little tough on the starter. It cranks right up with no hesitation, and runs great so we'll see how it runs for a week or so and then make some adjustments if needed.
As far as upgrades go, I was thinking new injectors, and now that it has a little better cam (from what I understand), maybe an upgrade over stock injectors? In my limited experience with injectors on my diesel motor, I know that the springs inside determine the "pop off" psi, and that the orifice sizes can be changed as well. Knowing how into it alot of you guys are, I was wondering if someone could suggest a good brand, spec, or something in our search for injectors? Does anyone know the specs of the bronco injectors and the stang injectors?
Someone mentioned 1.7 rockers- What would be the advantage? Would this mod require more than just changing the rockers?
One thing we have to keep in mind though, is the fact that this motor has 90k+ miles on it. I don't want to speed up it's demise. Let's face it-the boy likes mud, but the motor is gonna work for it.
Just a couple thoughts I had cause I know now that he has it back, running better than when he got it, he's gonna want more!
#38
on
If you got a 5.0 with the 15426378 firing order you don't have a HO, just a plane jane 5.0 from a Crown Vic or something. To confirm look for a capital letter cast into the top front corner of one of the cylinder heads near the valve cover, if it's an S you don't have a HO.
Longtube headers are the only way to get a bit more torque out of the 5.0, 1.7 rockers will help it breath better as well.
#40
Originally Posted by cfrives3
It ended up being the 13726548 firing order, and the guy I guess had said it was a stang motor. How much are those rockers for a set?
Also, I wouldn't mess with bigger injectors, unless you want to get a custom chip for it. The engine will run pig rich with bigger injectors.
#42
the stock springs can almost coil bing when just swapping rockers.
Could you explain what you mean here?
#43
on
Originally Posted by s1120
The longer rockers[or a aftermarket cam with more lift] moves the valve farther down into the cyl. Well the stock springs are set up for a cirten ammont of travel.
#44
#45
thanks for the ideas guys. what are the biggest injectors i can run with the 1.7 lifters?
what else should i do to optomise the effect of these upgrades? headers, i assume, but what about a hotter coil? i have a set of taylor spyro pro 10.409 wires on it that my neighbor had from when he worked there. what needs to be done to make these add to the performance of my motor, in addition to just looking good?
