99 F150XL 4.2, battery-relay-starter wiring diagram... - Ford Truck Enthusiasts Forums
Old 11-21-2007, 08:44 PM
mlongue1 mlongue1 is offline
mlongue1 is starting off with a positive reputation.
<TABLE cellSpacing=1 cellPadding=4 width="100%" border=0><TBODY><TR><TD class=msg vAlign=top width="100%" bgColor=#f1f1f1>99 F150XL 4.2, battery-relay-starter wiring diagram... is there an online diagram anywhere that shows this?... I want to make sure the wiring is correct before I jump to any conclusions... on this truck, the battery cable assembly is one piece with the starter and relay cables, and the assembly is still in original condition, ends corroded, going to replace, (truck has been sitting up for about 2 years), and there is a small wire hanging loose with the end broken off, down near the starter, a small red wire (10-12 gauge?), and it must go to something, obviously... if I had a diagram, I could see how many wires and which go to the solenoid, etc. ... I have a Haynes manual, but it is not covered in the manual... and the relay is different from the one in the book, connections marked different and relay rotated 90 degrees... anyway, any help will be greatly appreciated, thanks in advance, and have a great Thanksgiving weekend!!...
</TD></TR><TR><TD width="100%" bgColor=#e5e4e9 colSpan=2><TABLE cellSpacing=1 cellPadding=1 width="100%" border=0><TBODY><TR><TD></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
Custom speedo cables and ratio adaptors. JEFFFAFA 1967 - 1972 F-100 & Larger F-Series Trucks 4 08-14-2014 06:52 PM
just so you'll know vloney 6.7L Power Stroke Diesel 6 11-02-2013 10:56 PM
someone dissed my truck today WoomaHodal Ford Inline Six, 200, 250, 4.9L / 300 72 02-20-2013 06:49 PM
Decoded VIN Wicked Endings 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 05-09-2010 08:22 PM
Hey Mediaman - 97 AWD HasBen Aerostar 1 12-10-2005 10:51 PM
Tags
1978, 1999, 42, 99, battery, circuit, connection, diagram, expedition, f150, ford, location, relay, starter, wire, wires, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
