Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-21-2007, 08:40 PM
avator avator is offline
avator is starting off with a positive reputation.
Question tailgate weight?
what is weight rating for an F150 tailgate? how much weight can I safely put on it?
thanks
  #2 (permalink)
Old 11-21-2007, 09:36 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) is gaining momentum as a positive member of FTE.
i will guess two heavy guys or about 400# would be o.k. if you concentrate the load at the center of the gate, outer edge, you miy put a bend in it. if you are spreading the load out or loading at the left and right sides by the cables, then you are in much better shape. lalying a 5 ft long 2 x 12 side to side under the load might help... what you hauling?
  #3 (permalink)
Old 11-21-2007, 11:01 PM
fire240's Avatar
fire240 fire240 is offline
the polar bear
2009 Ford F-150
fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold fire240 is a splendid one to behold
i know that i have put at least 500 pounds on my tailgate, but that was when i worked for a cemetary. me and the boss had to deliver a headstone to another cemetary.
__________________
Shaun from Dundalk,MD
2009 F-150 Super Cab XL 4X4 4.6L 2Valve V8
  #4 (permalink)
Old 11-22-2007, 09:37 AM
Quote:
my 715# Harley, plus my 235# when I ride it up into the bed - so, 950#, or so. I thought about removing the tailgate whenever I carry my bike (it's a long bed).... or a second (and not as good) idea is to get a small trailer.
  #5 (permalink)
Old 11-22-2007, 11:37 AM
galaxie641 galaxie641 is offline
galaxie641 is gaining momentum as a positive member of FTE.
Yeah it is a lot. I've easily had 700lbs on mine. The weakest point in them as I have seen is the actual hinges, I've bent them a time or two just barely backing into stuff. IIRC the hinge on the D. side is the one that moves the easiest.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'92 Grand Marquis
'97 F150 5.4L
'08 Bullitt #3947
  #6 (permalink)
Old 11-22-2007, 12:02 PM
builtfordtough13's Avatar
builtfordtough13 builtfordtough13 is offline
1978 Ford F-150
My Garage
builtfordtough13 is gaining momentum as a positive member of FTE.
More than a new tundra!!! pretty much what people have been saying.
__________________
Jake
DD:1994 F-150 4x4 Supercab, 351, E4OD,170k Rough Country Leveling Kit and 9000 Series Shocks
Project:1978 F-150 Reg. Cab 4x2 302 c4 Edelbrock Carb, Cam and Intake, TCI Shift Kit, 3.70 Gears
  #7 (permalink)
Old 11-22-2007, 12:46 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a good reputation on FTE. ATC Crazy has a good reputation on FTE. ATC Crazy has a good reputation on FTE.
This is the weight limit:
__________________
-2006 Dodge Ram 3500 ThunderRoad ed. CTD, 6-spd, and 4" straight pipe!
-1985 Toyota Pickup
-1978 F150 - 466ci/4-spd/4" lift/35's
-1978 Bronco - Parts
  #8 (permalink)
Old 11-22-2007, 02:21 PM
HEY - THAT'S MY SISTER-IN-LAW!!!!
I thought we destroyed all of those photos.
  #9 (permalink)
Old 11-22-2007, 03:18 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE. BLK94F150 has a great reputation on FTE.
Quote:
That took longer than expected to come out.
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #10 (permalink)
Old 11-22-2007, 10:55 PM
thanks for the responses. guess I'll remove the tailgate and carry my bike like that. really don't have the room around the old casa for a trailer.
  #11 (permalink)
Old 11-22-2007, 11:38 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold fordboy_52 is a splendid one to behold
Quote:
im pretty sure this is the gal i picked up at the bars the other night, she was better looking when i was drunk tho
Matt
__________________
Matt - Kansas State University ALUMNI!
2000 f-150 5.4 triton 4x4
  #12 (permalink)
Old 11-23-2007, 03:04 AM
87 XLT 87 XLT is online now
87 XLT is gaining momentum as a positive member of FTE.
Don't know on the F-150, but the owners manual for my Ranger sez: "Caution the tailgate load should not exceed 500 pounds."
  #13 (permalink)
Old 11-23-2007, 09:16 AM
Moore FOMOCO Moore FOMOCO is offline
Moore FOMOCO is starting off with a positive reputation.
I know I put a Pontiac 400 long block with alt. starter, headers on it and it closes fine, that had to be 850++. Of course that ain't got nuttin on that ol Sal... I mean gal.
  #14 (permalink)
Old 11-23-2007, 12:21 PM
ATC Crazy's Avatar
Quote:
Yup...I've had a Chevy 350 with a transmission hooked to it sitting on my tailgate before. Not to mention my ATV's when I load them. 650lb and a 400lb ATV, plus me on them (220lbs).
__________________
-1985 Toyota Pickup
  #15 (permalink)
Old 11-23-2007, 06:23 PM
I'd hope the Ford would have a rating at least as high as the Dodge Dakota... I loaded a buddy's bike in his bed a week ago. he has the short bed so the rear tire sat at the back edge of the bed for a 4 hour drive. of course his Yamaha is about 100 lbs lighter than my bike... but still...............
maybe I'll just try it, and if it bends the tailgate... then I'll know.
Tags
07 , 2005 , f150 , ford , fx4 , gate , limit , load , maximium , pickup , put , ranger , rating , tail , tailgate , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
