6.0 v 7.3 MPG Towing & Empty
Probably too darn many variables to get a good handle on the difference;summer vs. winter, highway vs. city, bigger tires, individual driving style......
I have an '06 F250 6.0, 3.73 axle and Manual trans. At 60-65 mph on the highway, in the summer, with 265/70x17 tires at 65 psi, I can sometimes get just over 20, usually just under 20. At 70-75 mph, it's closer to 18. In the winter, with 285/70x17 tires at 55 psi, you can knock off 2 to 2-1/2 mpg.
Around town, it's 17 summer & 15 winter, but I'm a pretty smooth, conservative driver.... can't see smokin' the tires to impress people at $200 a tire.
Towing a 33' Travel Trailer at 65 mph in the summer, it's between 13 and 14.
Like wwb said there are alot of variables. When I drive my pickup 65 it makes 22. I rarely drive that slow, but the few times I have and checked the mileage that is what it did. 75 to 80 highway only ranges from 19 to 20 depending on wind and terrain. Most of the time mixed driving gets 17 to 18 depending on how easy I am on the throttle. Towing our 34' 5er 12 to 13.
Basically if you keep your speeds low on the interstate you can make some really good mileage.
BTW I dont keep track of mileage in the winter, blended fuel is alway worse mileage.
on
Originally Posted by mizzitch
Does anyone have a good handle on any MPG difference btwn these two engines?
Driving habits will give you the biggest difference in MPG's, but generally speaking the 6.0's are a quicker motor with slightly worse mileage. I'm currently running (4) 7.3's and (4) 6.0's at work. Proper driving in the 6.0 can be better than bad driving in the 7.3, but with the same driver in both trucks the 7.3 wins the MPG by a little.
on
Originally Posted by tex25025
You also have to take into account the setups of all those trucks: gearing, DRW or SRW etc. or else it's not going to be a really fair comparision. There are just too many variables, in order to have a fair comparision you would have to have both trucks configured exactly the same and try to drive them both the same way as best you can and travel the same exact route and then you would be able to have a much better estimation of mpg of one motor over the other.
on
Sorry I wasn't clear, but my observations are all on completely stock trucks that are similarly equipped. I have personally driven the different trucks so I'm making my comparisons on both my driving experiences and the MPG average of the trucks after they were put in the fleet.
