Replacing Thermostat on Explorer 4.6 V8 - Ford Truck Enthusiasts Forums
Old 11-21-2007, 10:48 AM
apropos apropos is offline
apropos is starting off with a positive reputation.
2000 Explorer, with Triton 4.6 V8 engine.
All seems fine, temperature is in normal range but there is no heat. The upper heater hose never gets even warm. I think it's the failed T-stat.
Where is it located, at the engine end of the upper radiator hose?
Any special advice on how to replace it?
Better to get OEM T-stat than aftermarket?
Old 11-21-2007, 02:25 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
If the temp is normal, I doubt if it's the Tstat. I could be air in a line or a heater control valve or core issue. I'm sure someone with more knowledge of the 2000 V8 will jump in.
Radiator Softballdad 6.4L Power Stroke Diesel 1 02-14-2015 12:10 PM
Cooling system questions blackjack33 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 10-10-2014 08:05 AM
Engine overheating KR1 1997-2006 Expedition & Navigator 13 06-25-2009 02:59 PM
Mocha Motor Oil - Yum! nicknels 1997 - 2003 F150 2 02-17-2009 05:29 PM
98 E350 no heat joe35098 1968-2013 Full Size Vans 5 01-17-2006 09:09 PM
Tags
02, 2000, 2004, 2006, 46, change, engine, explore, explorer, exployer, ford, replace, replacement, replacing, thermostat, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
