axle codes
27 — 3.31 non-limited slip (F-250)
26 — 3.73 non-limited slip (F-250)
I don't know why you'd have that on a F150.......
Check the rear axle bolt cover there will be a metal tag on the passengers side.
The numbers closest to the bolt holding the tag on will be your gear ratio. So if it shows 3L73, then you have 3.73 gears w/ limited slip.
These are the codes for F150s:
19 — 3.55 non-limited slip (F-150, Econoline)
17 — 3.31 non-limited slip (F150, Econoline)
H9 — 3.55 limited slip (F-150, F-250)
B6 — 3.73 limited slip (F-150, F-250)
V956F
73 75 3J23
On the driver side, the tag said
EHP OIL ONLY
Y75W900FEHP
thanks again
Originally Posted by bowkill
V956F
73 75 3J23
EHP OIL ONLY
Y75W900FEHP
thanks again
First number shows you have 3.73 gears. Yes the bolt does block a little, but if you could tell if there is a . or L right before the 73, then that'd tell you if you have limited slip or not. The L stands for LS, and the . means open.
According to your door code it is open.
I didn't know they offered 3.73 open differentials...... Then too I haven't been looking into much since 04.
Bottom numbers- use 75w90 gear oil.
Edit: Wow 5,000 post! I'm supprised ya'll didn't tell me to shut up yet.
vaporhp
02-19-2023 05:01 AM
boggerted
16
02-17-2019 12:50 PM
