You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
differences between car and truck flathead motors?
Hi, all...
Hopefully someone here knows. I have a chance to get a 239 out of a car. I know the tranny is different, bell housing, etc, but if I use my flywheels, etc, will the car flattie work?
Thanks,
R
__________________ Roger Phillips Oxford, IN Click the link for pictures of my truck: 1951 Ford F2
In a word, YES as long as it is the late series (8BA). Actually a 59A would work with a few more adaptations.
I've heard the truck cam is different, but I haven't heard that from the cam people.
Otherwise it's the same engine. Waterpumps will need changed. Might have small drive belts up front where the truck uses wide belts. Oil filter might be located closer to the front than the truck, but drop it in and bolt it up.
I'm not sure you'd even have to change flywheels unless the car's isn't drilled for your truck's pressure plate pattern - there are a couple variations out there.
