black smoke - Ford Truck Enthusiasts Forums
black smoke
Old 11-19-2007, 11:29 PM
Mat Dope Mat Dope is offline
Mat Dope is starting off with a positive reputation.
black smoke
if running b100 can you still make black smoke like you could with dino?
Old 11-20-2007, 10:49 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Black smoke is unburned fuel.
BD is oxygenated, unlike #2, so it tends to burn more efficiently.
I suspect you can make smoke with BD but it will be harder to do so.
Old 11-20-2007, 11:20 AM
yeah i know its from over fueling and stuff, i just dont know if it burned black like that. because i plan on makeing my own bio most of the time and was just wondering in a smoke tune from dp tuner if it will still get all that black smoke flowing.
Old 11-21-2007, 02:07 PM
Corey872 Corey872 is offline
Corey872 is starting off with a positive reputation.
The engines I have seen run both fuels, the BD smoked a lot less under the same conditions - some would quote around 50% less. I guess if you changed the parameters - either tuning specifically for the BD, or dumping in more fuel, the smoke could be affected either + or -.
Old 11-21-2007, 09:48 PM
adambomb's Avatar
adambomb adambomb is offline
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
i don't really see any black smoke when i run b100, if i really get on it i sometimes see a greyish black haze come out but its nothing compared to what my truck will do will spew using Diesel.
Old 11-21-2007, 10:03 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I think black smoke is very hard to come by on Bio, even as low as B20. I tried B20 on my farm tractor and the black smoke disappeared. All I get now is a faint white smoke. The thing I noticed the most on the tractor is all the junk it blew out of the exhaust pipe for the first tank.
Old 11-21-2007, 10:06 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
when I am running bio I can get some smoke on my smoke tune but it clears up real fast. So simple answer is yes it still will smoke black but won't be as much or as long.
Old 11-21-2007, 11:46 PM
cool thanks guys thats what i was wondering dont worry this wont defer me from bio just wondering what to expect.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
