Thats not true, pure ethanol is about 129 octane. Everclear is pure ethanol, you know what happens when you drink that stuff? You go blind. Any alcohol not sold for consumption is required by law to be made poisonous.
Ethanol is about 113 octane from the quick research that I did based on the fact that they are using/going to use it in indy.
Ethanol and Methanol are both toxins. Methanol is more substantially toxic than ethanol.
Everclear is 95% ethanol not 100%
Yes it is and i have run 1 tank of e85 so far. MPG went down by 1.5
On a 20 gallon tank with E85 70 cents per gallon cheaper you are still ahead $12.60 per 20 gallons. Not only saving money but helping to lesson our dependancy on foreign oil. Good Deal!
Benning, what would it eventually cost the economy if we DIDNT send the troops to the middle east? Maybe you should read up on WWII. You havent had to sacrifice basically ANYTHING
Benning, what would it eventually cost the economy if we DIDNT send the troops to the middle east? Maybe you should read up on WWII. You havent had to sacrifice basically ANYTHING for this war.
Reason: delete
