Torque converter clutch lockup switch - Ford Truck Enthusiasts Forums
Old 11-19-2007, 03:58 PM
Skandocious's Avatar
Skandocious Skandocious is offline
Skandocious is gaining momentum as a positive member of FTE.Skandocious is gaining momentum as a positive member of FTE.
I know this has been covered before, and I bookmarked the thread, but I've got another question. I'd like to install a torque converter clutch lockup switch that will allow me to lock the converter at any speed/RPM but I'm a bit confused as to how the electrical circuit works. The torque converter is UNLOCKED when it has +12v to it and LOCKED when the voltage is removed? Or vice versa? Thanks.
Old 11-19-2007, 05:20 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Nethier.
The clutch is on when grouned, off when not grounded.
Old 11-19-2007, 05:27 PM
17fordguy's Avatar
17fordguy 17fordguy is offline
17fordguy is starting off with a positive reputation.
what is the point of this mod
Old 11-19-2007, 05:37 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
Quote:
It allows him to manually lock the converter rather than having it slip.
Old 11-19-2007, 05:39 PM
MisterCMK's Avatar
Avid Winter Hater
The solenoid always has 12 volts to it. The ECU provides the ground when it wants to lock the converter.
Old 11-19-2007, 05:44 PM
So then installing a switch inline on that wire would only allow me to UNLOCK the converter when it has been locked already be the ECU, by breaking the ground. No? If I wanted to lock the converter on command then I'd need a three way switch with the center prong running to ground, no? But then I wouldn't be able to restore the originial circuit...
Old 11-19-2007, 06:03 PM
MisterCMK's Avatar
Avid Winter Hater
To UNLOCK the converter you would break the connection between the ECU and the transmission. This site has a good diagram with LEDs for ya.
http://www.forgotton.net/mods/tclock/index.htm
Old 11-19-2007, 06:25 PM
subford's Avatar
No center goes to the transmission.
Old 11-19-2007, 06:33 PM
Ahhh yes it makes sense now!! You guys are awesome. Chris I gave you rep points but Bill I can't give you more until I "spread it around". Thanks you guys.
Playa_fl Playa_fl is offline
Playa_fl is starting off with a positive reputation.
What are the benefits of manually locking/unlocking the torque converter? I have no clue about how this works. When its locked what does it do? Sorry to thread jack
Old 11-19-2007, 06:38 PM
subford's Avatar
That is OK, it seams like almost no body in the 1987 - 1996 F150 And Larger F-Series Trucks forum likes to give rep points. As long as I have been on here and as many posters that I have helped I only have 159.
Old 11-19-2007, 06:54 PM
I know Bill it kinda sucks... I know I'm not nearly as knowledgable as you but when I actually DO know something, I don't get the rep for it...
Playa_fl, click on Chris's link above and it explains the benefits of the TC lockup switch at the bottom of the page.
Old 11-19-2007, 06:56 PM
subford's Avatar
Quote:
The computer will lock the transmission to the engine at about 43 MPH using a lock up clutch in the TC for better MPG.
If you have the Mod it can be used for towing above about 25 MPH and engine braking. This can also keep the oil cooler in the transmission.
No Torque Converter Lockup.... ABS Light Beastlyforddude 1987 - 1996 F150 & Larger F-Series Trucks 16 02-16-2011 01:52 PM
E4OD trans temp questions jimjoebob99 1987 - 1996 F150 & Larger F-Series Trucks 17 05-13-2010 06:43 AM
Torque converter lockup bhd 6.4L Power Stroke Diesel 5 03-08-2010 08:52 PM
Lock up torque converter rpcarlson 1997-2006 Expedition & Navigator 4 12-03-2005 01:52 PM
Lock-up torque converter for C6? Piffery1 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-03-2004 08:55 AM
Tags
1997, 302, 4r70w, converter, f150, ford, install, lockup, r470w, switch, tcc, torque, unlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
