7.3 Mpg Towing 5k Trailer On 99v10
dOES THIS SEEM OK TO YOU GUYS? I was hopeing to get around 9 but am only getting low 7's. I tow a Travel trailer that is 10' tall and 8' wide max loaded weight with full water and week worth of gear was 4900 lbs. I have a rebuilt tranny 3.73 gears new plugs air filter and fuel filter. Runs smooth and no other issues.
Headwind? Hills? Avg speed over the trip are the three biggies that will make or break MPG on a SD. I can get 11 towing my 8000 pound fiver or I can get 8. Drive 62 and I get about as good as it'll do. Drive 70 and I lose at least 2 MPG. Drive into a headwind and I'll drop 1-2 MPG. Hills...the same thing.
On the 87 octane...is that full petrol or some ethanol?...I found last year that when I ran the 10% ethanol cr@p I got really bad mileage.
Also with your 3.73's...do you lock out OD and just tow in 3rd? I also found when I had 3.73's...it actually ran better to lock out OD as there were almost NO downshifts that way...the V10 would pull very strong in 3rd gear up many good hills...at 65mph in 3rd I would turn 2700RPMs.
Do you have any oversized tires or anything?...I couldn't tell from your avatar photo...if you did upsize the tires...did you adjust your speedo...just a thought.
Another thing I can think of...are you carrying any weight in the bed to speak of and have you verified your weight via a scale or estimated?...I don't think the scale is important since you are only talking in the 5K# range...but more thoughts...
What about tire pressure...are they too low?
And my last thought...are your hubs locked for some reason?
Good luck,
joe.
Joe, Excellant questions. Tires are at full psi, Have not verified weights exactlly but are in the range... +-200 lbs. I do have a bed box but it is currentlly pretty empty(maybe 100 lbs total). I do think the fuel in WA is oxigenated at this time of year. I Just put on Warn Premiums and am positive they are "free". I use the truck to tow the trailer 90% of the time. Lets say the last 10 tanks towing have averaged 7.5 or so.
I do lock out OD IF the transmissins shifts more than once or twice in 5 minutes.
