Wow! just found numerous trouble areas
Originally Posted by superduty4x4
Usually with the tensioners there is a square hole in them that you put a 1/2" drive ratchet or breaker bar into, then pull on it to release the tension and remove the belt. Not sure on the PSD, but I don't know why it would be any different than most of the other tensioners I've messed with. Also, the tensioner is usually the smallest pulley, which makes it easy to spot.
The tensioner pulley is the same size as the idler pulley.
Here ya go:
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item </TH><TH vAlign=bottom>Part Number </TH><TH vAlign=bottom>Description </TH><TR vAlign=top><TD>1 </TD><TD>10300 </TD><TD>Generator </TD></TR><TR vAlign=top><TD>2 </TD><TD>8678 </TD><TD>Belt Idler Pulley </TD></TR><TR vAlign=top><TD>3 </TD><TD>2E884 </TD><TD>A/C Clutch Pulley </TD></TR><TR vAlign=top><TD>4 </TD><TD>2A451 </TD><TD>Vacuum Pump </TD></TR><TR vAlign=top><TD>5 </TD><TD>3A733 </TD><TD>Power Steering Pump Pulley </TD></TR><TR vAlign=top><TD>6 </TD><TD>6312 </TD><TD>Crankshaft Pulley </TD></TR><TR vAlign=top><TD>7 </TD><TD>8509 </TD><TD>Water Pump Pulley </TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner </TD></TR><TR vAlign=top><TD>9 </TD><TD>8620 </TD><TD>Drive Belt </TD></TR></TBODY></TABLE>
Thanks for the pic! So I just stick a torx bit (T50) in it and move it one way or the other to release the tension? That pic will come on handy when putting belt back on as well. When the engine is running the water pump pulley looks as if it's out of balance. In other words, not turning in a straight circle if that makes snese. Where can I order one of these and does it just come off and replace with a new one?
on
To get the belt off you get a socket (mine uses a regular bolt head) or torx which ever it is and push it to the passenger side then slip the belt off the easiest pulley to get to. I will get you a pic in the next hour or so.
Also for the water pump pulley once you get the belt off check the waterpump for a loose bearing. if its not loose I would worry about what the pulley looks like it could just be an elusion(sp?) with the paint marks for something.
The thermostat neck and oil cooler parts can be had at your not so friendly Ford dealer but you will certainly get them cheaper at the webs sites.
The oil pan is sealed by a special silcone sealant but I would guess its not the pan leaking that is causing that oil drip. I think it might be coming from your oil cooler.
I will return in a while with some pics for you.
on
Here a tensioner pic
Tndiesel you not the only one who has leaks! went to tak e apics of the tensioner and noticed that my Thermostat housing is leaking as well after I did my thermostat a week ago or so. Guess I gotta reseal mine as well.
Anyway I would get a few cans of brake cleaner and clean all the oil from the power steering lines and verify they are relaly leaking cause it would not be unheard of to either have the oil cooler getting oil on them or have it coming fromw somewhere else.
As for the water pump pulley Ford will be the best place to get it from.
tndiesel go here for a good pictorial and explanation with p/n's
http://rides.webshots.com/photo/1091...28475244Ddfqrf
Thanks for the oil cooler pics, but I'm sure when Itackle this I'll have many questions--bare with me please.
I am now attempting to get the belt off and check the pulleys. I have a 50 Torx bit that fits perfect into the 50 torx bolt. My Torx bit is L shaped like a Allen wrench. So when I put it in and turn it towards the passenger side of truck the bolt just broke loose and feels like it's just unscrewing. How the heck do I release the tension on the tensioner pulley now?
#28
#29
MAn, I'm a moron. Of course I was turning the wrong one, I got it off easy. Now for the pulleys--The little pulley at the very top spins free and well but it has just an ever so slight back and forth motion to it if I grab it at 9 and 3 position and try to rock it. Imean it's not much but it's there. I took it off and the torx bolt that goes through it has a hard plastic thing over it that allows the pulley to spin and that is where the slight play is. I don't really know if it's normal or not because I've never checked this before.
The other pulley that is the same size as this one also spins freely and has absolutely no play at all when I grab 9 and 3 and try to rock it. Water pump pulley is good and everything else except: The power steering wheel has no side to side play but will go in and out if you push or pull on it about 1/4 to 1/3 of an inch. It appears this is supposed todo this but again I have no idea. It also doesn't appear to have a torx bolt holding it on but something with a hole in it. So I'm obviously confused somewhat, thanks for all ya'll's halp and patience with me.
#30
