No spark, fuel pump not kicking on, PLEASE HELP - Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
Old 11-18-2007, 05:12 PM
MIKEBOYCE94's Avatar
MIKEBOYCE94 MIKEBOYCE94 is offline
MIKEBOYCE94 is starting off with a positive reputation.
Cool No spark, fuel pump not kicking on, PLEASE HELP
]I'm a chevy guy but came across a steal on a 94 ford ranger ex-cab 4x4 lifted 6in sus (superlift) on 33s it has a 4.0L V6 and its a 5speed with only 106,600 miles on it, here is the KICKER its been rolled 3 times I got it for $900 bucks to make a mud toy.
I put a new battery in it (Its been sitting for about 4 months) turned over and over Nothing, I checked the fuel pump cut off switch it was reset (the kid b4 me reset it) checked all the fuses inside and under the hood, and fuel pump relays, there all good, I put a new coil back on it, nothing,
I finily cut the 2 wires going to the ernursha switch (fuel pump kill switch) twisted them together, nothing so I ran a hot wire right off the battery to the fuel pump kill switch wires and it kicked right on and I tested it at the fuel rail and it hade good fuel pressure but still no spark?
I'm lost I got people sayen crank sensor and than others saying the pcm in the pass side lower kick panel? I'm at a loss? the truck was running and driving fine b4 it rolled, it sat for 4 months, and I bought it HELP!!!!
Thank you
Mike Boyce
Mikeboyce94@hotmail.com
Old 11-23-2007, 01:44 PM
toddn78 toddn78 is offline
toddn78 is starting off with a positive reputation.
Check all your grounds good,especially the firewall to the motor ground. sometimes multiple problems can be caused by something as simple as that.
Replace fuel pump without dropping gas tank Jymmm Expedition & Navigator 19 09-08-2016 12:53 AM
04 6.0 cuts out Vincent Dudelis 6.0L Power Stroke Diesel 1 10-26-2015 06:30 AM
Electric fuel pump conversion (pics) fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 31 07-11-2015 09:36 AM
new to the site. stumped. ingram 1987 - 1996 F150 & Larger F-Series Trucks 12 12-26-2014 03:01 PM
no fuel no fire 3??4x4 1987 - 1996 F150 & Larger F-Series Trucks 21 03-23-2014 01:49 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2004, 86, 97, coming, explorer, f250, ford, fuel, kicking, kill, passing, pump, rangerfuel, spark, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
