Reuse of copper gasket
Old 11-18-2007, 12:36 PM
kawa's Avatar
kawa
kawa is offline
Is the two sided rectangular copper gasket that fits between to incoming exhaust manafolds and the turbo reuseable? Also I have heard that by heating copper with a torch will re-soften the metal!?
Any thoughts? Comments?
Roger
Old 11-18-2007, 12:58 PM
audimaster's Avatar
audimaster
audimaster is offline
Annealing is the process you are speaking of. Many people say to quench the copper in water after it is red hot. Quenching it in water is not needed for this metal. I do this all the time to washers. Give it a try. Check for soot leaks after a few miles.
Old 11-18-2007, 01:56 PM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
Roger I have reused them a few times with no trouble.
Old 11-18-2007, 03:37 PM
kawa's Avatar
kawa
kawa is offline
Thanks guys becuz my dealership is out of stock.
Rog
Old 11-18-2007, 04:02 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
Annealing the copper is the best way to guarantee they will seal again. I carefully use an Oxy/Acetelyne torch. Use full Acetelyn to blacken (soot) the copper, turn on the oxy, then burn off the the soot...softens the copper.
Wyowanderer
12-17-2016 09:20 PM
Rasputin53
07-05-2016 12:46 PM
Runningaddict
12-31-2015 02:36 PM
virgojeep
11-15-2009 02:54 PM
jowilker
26
09-12-2009 09:24 AM
Quick Reply: Reuse of copper gasket
