Dually Questions
Dually Questions
Im buying an 05-07 350 Dually crew cab diesel soon. It will probably be the King Ranch because their are a couple nice ones right around my area.
My first question is, what kind of fuel mileage can be had with one of these trucks. I plan on doing 4" turbo back magnaflow, and a K&N intake, and a superchips programmer for sure.
What else should I do for mileage, im not worried about power because im only pulling a 32' enclosed with a race car in it and my V10 does it now with no problems.
Also I know all duallys come with 4.10s(or I think) can you put 3.73's from an f-250 or another f-350 NON dually in a Dually rear end?
I didnt/dont know for sure if the ring gear sizes are the same.
Thanks guys for any help.
I used to get between 11-12 towing, 8-12k at 60mph. W/O towing I could get 13-14 if I drove nice or 11-12 if I drove over 70mph and punched it at stops. I havn't recaulculated with the new tires yet.
I am sure the magnaflow would be fine, but the majority of people would say not to use the K&N on a diesel and never use a superchip. And before you do either you need to get gauges. I don't have either on mine yet. After I put some more miles on it, I am going with MBRP exhaust and XCAL II from Matt. Do some research in the 6.0 forum to get more info on intakes and tuners.
My DRW has a tow boss package that includes 4.30 gears. I am pretty sure that the gears for the DRW axle are not interchangable with a SRW but I could be wrong, I am sure someone else could chime in. I would not want 3.73's in mine because of the amount of towing I use it for. The 4.10 are a good middle ground if you plan on driving without a trailer a lot.
The way I see, I didn't exactly buy mine for fuel economy, most of the time I use it, I have a trailer in tow. You didn't mention if you were looking at 2x4 or 4x4, because that will change a lot with your milage. I am holding off on performance upgrades for a little while longer, I am very happy with the stock performance most of the time.
Good luck, and do some more research on the 6.0 forum, there is a lot of reading but its worth it.
SRWs are Ford/Visteon 10.5" rears.
DRWs are Dana 80
Not interchangeable.
With the 6.0, I would just stick with the stock intake.
If you want aftermarket, AFE or Air Raid are a couple of the better ones.
SCT is the most popular as mentioned. A bunch of my friends run them with either DJ's tunes, Doug's tunes (GoGo Diesel/Direct Injection Performance), or Innovative.
DRWs are Dana 80
Thanks guys for the quick responses..
-Im in no way shape or form looking to get a truck and expect a lot of gas mileage from it, but I would like to get decent because the majority of my driving is without trailer. Although this year it will change quite a bit so i'm not sure... I just dont have the extra money for a daily driver car right now while building two muscle cars.
-I will look into the trucks i'm getting and check the gear ratios, i thought they were all 4.10's.
-And I was only going with K&N because I get a killer deal on them through my warehouse, but i'll look into that stuff more in the 6.0 forum.
-Does anyone if they make gears for f350 duallys?
-BTW I am going to get the 4x4..
Thanks again guys
Thanks again guys
Originally Posted by DCSpecial
Ford/Visteon/Sterling.....all the same thing.
...Does anyone if they make gears for f350 duallys?...
http://www.ringpinion.com/
Originally Posted by mudmaker
you migh want to check the ratios, not all duallies are 4.10s. There are alot 3.73s out there.
I currently am getting around 14 mpg unloaded and getting ready for my first trailer haul with a miata on board a 6 x 16 trailer from Little Rock to Dallas on Wednesday, so I will post back my MPG with this load (I figure 3000-3500 pounds max).
okay so made the trip to dallas with miata in tow (realized at Texarkana that had forgot loading ramps, but made due with a couple 2 x 10's) and I clocked 292 miles to my destination and made the return trip to Mt. Pleasant for a total of 392 miles at 12.1 MPG. I drove 60-65 on the trip down, and 70-75 unloaded with trailer in tow
My mileage, trailer only, from Mt Pleasant to Home at 70-75 was 13.25 MPG.
I certainly hope I can make this better with a few mods, mostly for state of mind....
I get between 12.5 and 13 mpg around town with my 2005 F350 DRW PSD.4:10 rear ends. On a road trip without getting carried away with the speed I get around 14 mpg. If i nail it, I kiss my fuel mileage goodbye, but I didn't buy it for fuel mileage, I have the 4 cylinder Ranger to run around in, if i want fuel mileage..
2005.F350.PSD.CC.DRW.LWB.FX4.4:10's.King Ranch.Oxford white/Arizona beige. Stock motor.
With my 06 cc 4x4 dually, I get 13-14 driving either in town or highway, it never varies. I have the air-raid 4 in exhaust and hypertech tuner(stage 1 or 2- never 3 on tow). I also put 285/70 on it too which killed mileage. Prior to the tire change i once got 17 on a non towing trip with cruise on. 410 rear. now towing i get 8-9.5mpg depending if there is a head wind. i tow a 40ft 3 axle 5th wheel that is pushing 17k loaded (rated 18k max). it does make the truck squat but air bags took care of that. I am looking into an F450 but have mixed emotions
I can definitely live with like 13-14 around town and same or more on the highway. My truck now gets like 11 or 12 around town and about 15 on the highway unloaded.
And like I said im either getting a new Bonneville or a Ranger maybe for daily driving...
Im excited now, I cant wait to get mine this spring.
And if the 4.10's proove to be too much ill just switch to 3.73's no big deal.
