It appears the the lighting for the climate control (manual system, standard 3 dials) is out. Al other lights work fine, Anyone know the details of how to fix?
This is all that my manual refers to. Not a difficult job for any DIYer.
<TABLE width="95%"><TBODY><TR><TD>SECTION 412-04: Control Components
</TD><TD align=right>2000 Expedition/Navigator Workshop Manual
</TD></TR></TBODY></TABLE>
REMOVAL AND INSTALLATION
<HR>Bulbs —Electronic Automatic Temperature Control (EATC) Module
****** name=tps_proctitle content="Bulbs —Electronic Automatic Temperature Control (EATC) Module">Removal
Remove the control assembly. For additional information, refer to Control Assembly—Electronic Automatic Temperature Control in this section.
NOTE: Place the module upside down on a non-marring surface.
Unsnap the bezel and pivot it open.
To replace the general illumination bulbs, unscrew the lamp holders and remove the bulb.
To replace the HI/LO bulb, cut the wires close to the bulb base, splice the wires to the new bulb and wrap the splice with electrical tape.
