F150 Emergency Brake Stuck.......Help!!!! - Ford Truck Enthusiasts Forums
Old 04-04-2002, 04:39 PM
2002_SC_FX4_4x4 2002_SC_FX4_4x4 is offline
2002_SC_FX4_4x4 is starting off with a positive reputation.
Old 04-05-2002, 12:01 PM
Gov33 Gov33 is offline
Gov33 is starting off with a positive reputation.
I was parking my F150 last night, and when I put the emergency brake on it stuck to the floor board. The truck will still run, but the emergency brake light stays on, yet it's not working. Does anyone have any suggestions on how I can get the parking brake working again? And what the possible problem may be?? Cable stuck?? Any suggestions would be appreciated.
Matt
Old 04-05-2002, 02:51 PM
robrowe35 robrowe35 is offline
robrowe35 is starting off with a positive reputation.
you might want to check the brake cable underneith the drivers side of the truck and see if you snapped it. tug on it and see if there is tension. it is pretty easy to find, just to the outside of the frame and it splits to the leftback and the right back just behind the cab. was there resistance on the brake pdeal when you engaged the parking brake?
-r.r.
Old 04-10-2002, 08:24 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
wolfmanagh is starting off with a positive reputation.
My guess is it snapped. The cables will usally freeze if they are not used enough. If it did snap don't worry about or replace it put a little Anti-Seize on the cable and work it in. It will help prevent it from seizing again.
Offroad & 4x4 351slug Offroad & 4x4 7 03-16-2013 10:11 PM
4x4. 4x4 Off Road. 4x4 Sport. fx4. 4x4 STX Irish816 Offroad & 4x4 17 05-19-2010 08:08 AM
4x4 Offroad & 4x4 5 12-09-2006 09:03 PM
celebrating holidays in schools 4x4x4x4 General NON-Automotive Conversation 28 12-16-2002 01:54 AM
1965 3/4 ton 4 door CustomCab4x4 1961 - 1966 F-100 & Larger F-Series Trucks 5 02-03-2002 02:20 PM
Tags
2002, brake, emergency, f150, parking, sticking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
