Mine will not engage at all if I put it in O/D but seems fine if I put it in D, R, 2, or 1. Does that sound like a solenoid problem? I can sorta hear or feel it when I put it in O/D but then nothing.
No drive at all in the OD position, but works fine in D? That doesn't sound like a solenoid problem. The solenoids on this only affect the 3-4 shift and the torque converter lockup clutch. When these fail, the transmission would behave like a traditional 3 speed transmission (meaning that it would at least drive, just never upshift into 4th gear).
No drive at all is going to be something else. I recently saw a discussion on another forum where the poster had a similar problem (no drive in OD, but seemed fine in other positions) that turned out to be a bad OD sprag.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
Thanks. I came to the conclusion that it's a bad/broken O/D sprag. I don't know exactly what that is, but that's what everything points to. Will it hurt my trans to continute driving it in D? Is it likely it will suddently fail and not go at all?
__________________
In California, the Totalitarianism State.
