3.0L Ranger misfire
Old 11-17-2007, 06:21 PM
wheelie842001's Avatar
wheelie842001
wheelie842001 is offline
3.0L Ranger misfire
My 3.0 Ranger misfires about 20 seconds after startup, and continues to misfire. We installed new plugs and a coil pack. After initial startup, you can verify spark on all 6 cylinders with a timing light. After about 20 seconds cylinders drop out, such as 2 and 6. Sometimes 1 will drop out as well. Anyone experienced this?
Like i said before there is no evidence of a miss right after startup, it is only about 20 seconds into the run time that it happens.
Old 11-24-2007, 09:36 PM
99rangerXLT's Avatar
99rangerXLT
99rangerXLT is offline
I'm interested in wondering what the problem is cause my truck does the same thing. Sometimes it also does it at about 3,000 rpms but will clear out whenever my motor gets at normal opporating temperature.
Old 01-23-2008, 07:21 PM
jrwrocks's Avatar
jrwrocks
jrwrocks is offline
if it is run with a coil pack its bad. the controle moduel is biult into these and thats the only other thing that could drop spark
Old 02-11-2008, 04:47 PM
tomb1269's Avatar
tomb1269
tomb1269 is offline
The syncro can also cause this problem particularly over 3000 rpms as the ECM does not register fault codes on cam sensor over 2500 Rpm. The syncro will also tend to give you a whine that sounds like a belt slipping when it is cold.
aeford66
1983 - 2012 Ranger & B-Series
10-05-2014 01:34 PM
Maddohalokiller
06-11-2014 03:42 PM
spawn_ta
03-09-2011 07:18 AM
88 Bronco
21
12-22-2009 11:46 AM
majoiner
3.0L V6
06-16-2008 07:51 AM
Quick Reply: 3.0L Ranger misfire
